Keypadlinc button number
I'm probably having a seniors moment here but maybe someone could refresh my memory.
So if I look at a KPL-8, for instance, grouped in my admin console I see all 8 buttons with the meaningful names I gave them.  But what happens if I can't see the KPL from where I'm sitting or I've pulled the buttons off it so that I don't know which is which.  There was (is?) a place where  the interface told me which button was which - if memory serves it  used to look like the devices were like ab.cd.ef.1 and ab.cd.ef.2 etc. up to ab.cd.ef.8
Is that still somewhere that I'm not seeing or has that been deprecated?
mark
Edited by MarkJames
Nor sure if this is what you're looking for but the order of the buttons is
     A B
     C D
     E F
     G H
lol - no, I know that...
Once you rename them, though, how can you tell which one is which without looking at your labels?
When you first link it it will name it
newdevice - A
newdevice - B
newdevice - C
etc
But once I change it to
Room Light
Table Lamp
Reading light
etc
How can I tell which button is, say, A, from the ISY admin panel without looking at the physical KPL.  I'm not sure if it was ISY or one of the other platforms I used prior to it that labelled them in the main device list with .1, .2, .3 or maybe it was .a, .b, .c...
mark
Edited by MarkJames
The Event Trace shows button number.
Thu 06/02/2016 12:24:01 PM : [iNST-SRX    ] 02 50 1B.57.F8 00.00.06 CB 13 00    LTOFFRR(00)
Thu 06/02/2016 12:24:01 PM : [std-Group   ] 1B.57.F8-->Group=6, Max Hops=3, Hops Left=2
Thu 06/02/2016 12:24:01 PM : [D2D EVENT   ] Event [1B 57 F8 6] [DOF] [0] uom=0 prec=-1
Thu 06/02/2016 12:24:01 PM : [  1B 57 F8 6]      DOF   0
Thu 06/02/2016 12:24:01 PM : [D2D EVENT   ] Event [1B 57 F8 6] [sT] [0] uom=0 prec=-1
Thu 06/02/2016 12:24:01 PM : [  1B 57 F8 6]       ST   0
Thu 06/02/2016 12:24:01 PM : [iNST-SRX    ] 02 50 1B.57.F8 22.80.0B 41 13 06    LTOFFRR(06)
Thu 06/02/2016 12:24:01 PM : [std-Cleanup ] 1B.57.F8-->ISY/PLM Group=6, Max Hops=1, Hops Left=0
Thu 06/02/2016 12:24:01 PM : [iNST-DUP    ] Previous message ignored.
Edited by LeeG
Thanks Lee - I was just looking at that....
Didn't the UI used to display it before?
I was sure that when you went into the Main tab and clicked on the root node of a KPL it brought up in the main properties window the name with the address and device type as it does now but with a suffix for which button it represented so that when you looked at the load button it would say
                     KPL-GARAGE
0A.AB.1E-1 (2486D)  Keypadlinc Dimmer v.2A
but when you looked at button B it would say
                     KPL-Driveway
0A.AB.1E-2 (2486D)  Keypadlinc Dimmer v.2A
Am I imagining this?
Could be... it would be a nice feature, though.
How did you get your button to show in event viewer without writing to it?
mark
Edited by MarkJames
newdevice - A
newdevice - B
newdevice - C
etc
Room Light
Table Lamp
Reading light
etc
mark
You could append the button letter to the name i.e.  Room Light (a),  etc.
Edited by Techman
I suppose...
Seems like there *should* be a way to see this directly within ISY, though...
mark
I pressed the button.
I've tried 3.3.10 on a 99i.  It does not show button number on the normal UI display of any of the buttons.
lol - direct approach.
I was sitting here in the house trying to reconfigure the buttons on a KPL down on my dock.  I couldn't remember which button was which as I've changed their functionality quite a bit.  I was trying to figure it out without walking down to the dock and either looking at it or - as you did - pressing the button.
mark
I'm not - I use the button names.
It's just for organization.  I wanted to make the left button on the second row into a controller for a different scene than it was already assigned to.  Without going down and looking at it I didn't know which scene the left button on the second row was already assigned to.
I suppose if I'd taken all the buttons off a KPL without noting what they were assigned to it would be a bigger problem - I'd have to reinstall it and press each button individually to figure out which was which.
mark
This is what I do when I originally set up a KeyPad:
post-625-0-21991500-1464902667_thumb.jpg   post-625-0-98350700-1464902768_thumb.jpg
I understand your dilemma. 3 of mine are in direct view of the computer and I turned their scenes on and off to see which one.
The others I wirenuted a cable with a plug, set them up at the computer for full functionality, then go install in their final home.
One other idea to do at the beginning is to add prefixes to the key names at configure time:
A-Lights, B-Garage door, etc. The AC alphabetizes the devices as they're renamed and that's when they move out of order
Paul
Edited by paulbates
Paul
Yep - I definitely *could have* or *should have* put a designation of some sort with each of my 160 KPL buttons but you know what they say about hindsight...
The alphabetizing is the problem.  If there was either a way to turn the alphabetizing off or to have the UI indicate which button is which I think that would be an improvement.  Perhaps I'll put this in as a feature request...
Just use a letter or number as the suffix (e.g., Kitchen Light_C)
Mark
I'll support that for sure. I keep saying I'm done implementing keypads, but...  :mrgreen:
As a suggestion, the requirement could be to add menu options when the keys are grouped under Main...Add menu options on the right-click for alpha order, or native (A-B-C) order. Just a thought
Paul
Paul
