Variable History?
I looked at the log and it doesn't appear to be there.
I know I can open up the event viewer and let that run (not sure if PC needs to be 'awake' for that to keep recording).
Is there any place that keeps a history of variable changes, or takes a snapshot over a period of time?
I'd like to see when my variable is changing.
Thanks.
This could be done with the internal ISY logging facility via the notification technique also.
There is a thread on this back a few months ago with mwareman, myself, and others.
Here you go:
http://forum.universal-devices.com/topic/7269-logging-variables/page-1
I looked through this and tried to follow some links, but had no luck (i copy pasted the actual link target):
http://forum.universal-devices.com/viewtopic.php?f=79&t=7763
http://forum.universal-devices.com/viewtopic.php?f=51&t=11857&view=next  (jumps to: http://topic/7293-isylogger-latest-version-v067/)
nevermind - i just popped it in the pattern of the current forum and it worked. that was confusing.
Edited by Jamison_IO
i am working on this and can't figure out how to monitor the variable to trigger the update. Is there a way to monitor the variable and write to file when it changes?
It must be a state variable, then it will trigger. Integer variables won't trigger automatically.
Thanks -I am using a state variable. I read the info, and am probably going about it all wrong.
I have the custom notification ready to go, I just do not know what to use in the program to trigger its use.
Edit - I am trying to use the internal logging, not the ISYlogger. I think that is where the disconnect is. My apologies, I should have been clearer.
Got it to work - it never says in the instructions what to use for the "Settings/Groups" in order to point it to the custom notification. That's where i was confused.
I use one notification to write the column headers each month for a new file.
I use another notification to write the data to the same file each time a variable changes.
I use mwareman's script and some plug-ins to view the data on a chart.
I have discovered a lot of flaws in my HVAC system using these methods.
To put one more option on the table, is io_guy's ISY Logger. I think it does exactly what you want and can ship the results to syslog if you'd like. You id the variables you want to track by checking a box next to their name. You do need a separate windows or Raspberry Pi type system to run it on your network
Here is a sample of the csv output.. header row definition, followed by values:
Time,Day,Month,Month_compare,Day_compare,V_FR_Fan_Cycle_Sequence,V_US_Fan_Cycle_Sequence
03/10/2016 00:12:40,9,3,3,9,29,52
03/10/2016 00:17:43,9,3,3,9,29,53
03/10/2016 00:32:41,9,3,3,9,30,53
03/10/2016 00:37:44,9,3,3,9,30,54
03/10/2016 00:52:41,9,3,3,9,31,54
03/10/2016 00:57:44,9,3,3,9,31,55
03/10/2016 00:59:58,10,3,3,10,31,55
03/10/2016 01:12:43,10,3,3,10,32,55
03/10/2016 01:17:46,10,3,3,10,32,56
03/10/2016 01:32:43,10,3,3,10,33,56
03/10/2016 01:37:48,10,3,3,10,33,57
03/10/2016 01:52:45,10,3,3,10,34,57
03/10/2016 01:57:48,10,3,3,10,34,58
03/10/2016 02:12:46,10,3,3,10,35,58
03/10/2016 02:17:49,10,3,3,10,35,59
03/10/2016 02:32:46,10,3,3,10,36,59
03/10/2016 02:37:50,10,3,3,10,36,60
03/10/2016 02:52:47,10,3,3,10,37,60
03/10/2016 02:57:51,10,3,3,10,37,61
Paul
