theedudenator Posted July 13, 2016 Posted July 13, 2016 I want to connect to my house remotely. I set up ddns service. I have the ISY working fine. I have the Elk M1Touch Pro software. I cannot connect with this. What do I use for the IP address? I am assuming the XXXX.ddns.com address? And I am using port 2601
MWareman Posted July 13, 2016 Posted July 13, 2016 Port 2601 is the secure port. You'll need to open port 2601 and forward it to your Elks M1XEP IP address to use the M1 software. Make sure the M1XEP firmware is up to date! The older firmware uses SSL3, and that's probably disabled on most phones now. The external ddns name is correct. An alternative is to buy the Elk module for the ISY and then control it thru the ISYs connection. On IOS, Mobilinc has an Elk module that can use this connection. On Android, I have an app published that uses this connection - or you could create your own interface using Tasker.
