Installer Software?? for use on laptop with Z-Stck - Issue returning ISY to Primary
Hi everyone!
I have the ISY-994 Zwave and a Aeon Labs ZW090 Z Stick. I am using Zensys-tools to control the Z-stick.
I am having issues returning the ISY to primary. The "Shift" button in Zensys is grayed out sometimes, when the Z-stick is the primary.
If I reset the ISY Zwave and then start over I can get it to work once. Then I can't go back .. getting tired of excluding all my devices and then re adding them every time I buy a new device.
What do I do when I shutdown the Z-stick, delete the device? Remove it after the ISY is primary?
Is Zensys the issue, is there something else I should be using? Free or otherwise at this point.
This is the only issue I have had so far.
3x Schlage locks
3x Trane 524 T-stats
4x GE dimmers
3x Slave rockers
1x Doorbell
ISY Portal & Alexa
It's also worth noting, when you shift primary you have to remove and re-enroll secure devices anyway, as the crypto key material is not replicated to the receiving primary anyway.
