ISY Portal Maintenance - 02-19-2017
Michel Kohanim
Hello everyone,
We will have a maintenance release next Sunday 02-19-2017 at 5:00 AM PST. You should not experience a downtime of more than couple of minutes.
This release includes a Node Server implementation for 5.0.9 firmware release. Our initial Node Server will be for Geo Fencing using any app that can call URLs (we tested with Locative):
- Basically, mobile devices can be grouped under a Location node which allows for such things as "Home", "Home larger radius" and "Country house", etc. @MWareman, thank you for the idea!
- The status of a location will be true if any of the member devices/nodes is true
- You can also have standalone mobile devices (e.g.) not grouped under a location. For example, you could have "at work" entry, not under a location. The idea is that you don't need to create a location if you are to use only a device in it
This is a huge milestone for ISY/Node Server since it provides us with the ability to add other Node Servers in the future without the need for firmware updates to ISY!
Thank you Chris!
Thank you Benoit!
      377.1k
