Odd Behavior from LampLinc/KeypadLinc/ISY Program
ResIpsa
I noticed at bedtime last night that the KPL status light for my wife's bedside lamp was blinking on and off. A quick peek at the nearest access point revealed that the LED was blinking like mad, suggesting a ton of traffic. It eventually stopped of its own accord. (Another button on the same KPL is a status for the lamp on my side of the bed, and I believe it was doing the same thing a few nights ago.) Here's my status program:
       Status  'Lmp.MstrBdrm.Cathy' is Off
   And Status  'KpL.MstrBdrm.A.Cathy' is not Off
       Wait  2 seconds
       Set Scene 'Scene.MstrBdrm.Cathy (Status)' Off
       Set Scene 'Scene.MstrBdrm.Cathy (Status)' On
And here's a shot of the event viewer on Level 3 before I disabled the status program:
Any ideas?
Hi Michel. The only device in the scene is the KPL button. The same button is in another scene where it is the controller and a LampLinc is a responder.
Hi Tim,
What devices are in the status scenes? I think you are getting into a loop situation.
Tim, you should be able to see if the program is looping by watching the Program Summary page.
Removing the Actions in the Else should eliminate any looping (as a test).
If the program was going to loop it should happen all the time, I don't know what could make it quit except turning the light back on.
When the button was flashing did it kill all your Insteon communication? One of my keypads went into a mode like that one time. I had to pull the set button for a few minutes and it has never happened again :?
Is this program used to check for local control of the LampLinc?
Rand
