Tools > Log returns an empty excel file
Do I have to turn on logging? When I go to Tools > Log it opens a spreadsheet that is blank except for having a sheet named UDI. Is this normal? I want to see what happened when a particular program ran and if it evaluated as true or false.
Once Excel opens you should see a dialog box asking if you want to either open or run (I think it says macro??), not sure of exact wording and I am not by a computer. Say yes and the file should open.
If you are not seeing the dialog you may be blocking this from running and need to check Excel settings.
Ok I enabled macros but now I get an error pop up at says:
Run-time error '75':
Path/File access error
Continue is grayed out, End and Debug are options. If I click Debug it goes to line 7 in the macro, ChDir (ThisWorkbook.Path)
