Lights turning on unexpectedly
I have a group of lights (which may or may not belong to an ISY scene) that has turned on to full bright. I don't know when or what causes this to happen but it is annoying the wife.
How can I track this down?
It matters if the errant devices belong to a scene or not for a possible solution.
Start with determining:
- are the lights part of a scene
- the specific time the lights come on unexpectedly
- whether a program fires at the same time
- other activty in the log at the same time
I had this happen many times.
From the admin console query each device and see
- if the level changes
- what the level is
- if the combination of device levels matches any of your scenes.
- if the status changes of the devices are recorded in the ISY log.
I haven't had problems with this for a while but to my best guess I had a OnOff appliance module spitting out bad code that matched a scene I have. Most of the time the ISY log had an error from the device each time this happened.
The cure - I unplugged it a and plugged it back in. I haven't seen the problem since,
This is not conclusive but a good indication and only time will tell...never know for sure though.
Just power cycling every device may fix it for you but I would want to, at least, get a suspect device first.
