May 18, 20178 yr Hi, Today I started having trouble connecting to my ISY via the portal. It normally works great, I haven't made any changes to the setup of Mobilinc, ISY or the Portal. I can access the portal via a web browser so it appears to be working. My ISY is also up and running. What else can I try to troubleshoot this? Thanks. Update Problem solved, the issue was on the ISY side. Edited May 18, 20178 yr by tmorse305
May 18, 20178 yr Hi, Today I started having trouble connecting to my ISY via the portal. It normally works great, I haven't made any changes to the setup of Mobilinc, ISY or the Portal. I can access the portal via a web browser so it appears to be working. My ISY is also up and running. What else can I try to troubleshoot this? Thanks. Update Problem solved, the issue was on the ISY side. It would be good to know what you found to fix this just for future users having similar problems.
May 19, 20178 yr Author It would be good to know what you found to fix this just for future users having similar problems. Good point larryllix, See this thread for the details of the fix. http://forum.universal-devices.com/topic/21794-current-state-missing-on-all-devices-on-admin-console/
May 30, 20178 yr Since I upgraded the mobilinc app to 4.12 i can no longer connect through https, My tls settings are 1.2, and I can access via web browser just not with the mobilinc app. I have a ISY994i pro, 4.5.4 And the portal appears online in the dashboard, I tried reboot both, isy and isp router but nothings change, I can access with mobilinc on local http just not outside. Any help will be much appreciated
May 30, 20178 yr Hi Bernardo, If you are using the MobiLinc Connect portal, open MobiLinc and go to Settings->Lighting Controller->Host type and select "MobiLinc Connect". Select "I Already Have an Account" and log in. If you can't get reconnected to your ISY through MobiLinc Connect, please send me a screenshot of your Admin Console->Help->About page to support@mobilinc.com so we can investigate. Wes
