Amazon Alexa to ISY Portal Connection -- is there problem (06-2-2017)
Tonight we came home and Alexa reports all ISY devices as "not responding".   I can login into the ISY Portal and refresh devices and all looks ok.   From the ISY I can control everything. I did the forget and discover and got no devices twice but they all came in the third time, but Alexa still reports them all not responding.
Same problem here.
Seems to be working now.
Sent from my XT1650 using Tapatalk
I asked Alexa what her status was and she did not understand how to respond to that so I provided feedback -- it would be nice if she could report service problems if she is working enough to respond at all.
Ok, now I'm calling a computer 'she' -- we are being assimilated.
I can confirm the same problem from Vermont.
-Xathros
Quick thread hijack (does it count if I started it? :-)
Xathros -- I see you have Emoncms -- what type of sensor did you buy to use it in the US?
Edited by mitchmitchell
My Alexa "smart home skills" did not list the ISY.
I added the "ISY Optimized for SmartHome v2".
I told it to forget my devices, and them re-discover them.
It found nothing...
Arrgh...
After hitting discover a bunch of times, everything has finally come back.
However "turn on desk lights" will result in "desk lights is not responding".
Come on - let there be light.
Edited by nickp
FYI from Amazon :
"8:48 PM PDT We have identified issues in AWS Lambda's capacity subsystem related to the increased API error rates and latencies in the US-EAST-1 Region and continue to work toward resolution."
Good to know. My daughter was pretty stressed out last night because all our FireTVs lost their connection to Amazon and stopped working for a bit. Other devices on the network were fine, so I assumed it was AWS related.
Now I have a ton of stuff at work to check... Since we use Lamda for a ton of stuff... :P
Interesting. Looking at my AWS dashboard, it seems that AWS retried and processed the queue. So, I likely didn't miss any notifications generated.
Given that Alexa apparently uses this subsystem, I wonder if anyone had Alexa commands process hours after the instruction was issued...
Edited by MWareman
Good question.
I looked at the logs, searching specifically for device discovery requests. Those are sent every hour or so for every ISY.
I can see erratic request for about 5 hours, and definitely 2 major drops in that period. I don't see spikes after it recovered.
It may be that device discoveries were blocked before hitting our lambda function.
Benoit
