Curb The Lights
I have a family member who will remain nameless that does not like the light being emmited from a Switchlinc relay in her bedroom. It keeps her up at night. Is there away to disable it completley? or atleast dim it down some what?
SmartHome sells some color change kits that definitely mute the light output, but in my opinion the available colors are a bit "cheesey".
They do have a frosted kit available, however, that isn't bad. Check it out here:
http://www.smarthome.com/2400LF/LED-Col ... ted/p.aspx
I tried one and personally thought it dimmed the LEDs too much, but maybe it would be perfect for you.
Perhaps you can celebrate Festivus now! :D
I had the same problem for one bedroom. I cut some label sticker to cover the last two led. It is barely noticeable and does the work.
RLav
