Programming with a motion sensor
I'm sorry for such a simple question. What I am trying to do is control a scene with a motion sensor. The sensor is in a work area of a barn which is controlled by a scene. It is not unusal to be out of view of the sensor for 10 minutes. If I try to control the scene by adding the motion sensor I can only set the delay to 8.5 minutes. So, I want to control it by program.
Program for Barn General
Status 'BarnGeneral Motion' is ON
Set Scene 'Barn General' On
No Actions
Control 'Barn General Motion' is switched off
And Control ' Barn General Motion' is switched On
Wait 10 minutes
Set Scene 'Barn General' Off
No Actions.
The only problen is it does not work. Any help would be appreciated. Than You.
Try this:
Program for Barn General On
->               Control 'Barn General Motion' is switched On
                  Set Scene 'Barn General Fast' On
                  No Actions
Program for Barn General Off
                  Control 'Barn General Motion' is switched Off
--->             And Control 'Barn General Motion' is not switched On
                  Wait 10 minutes
                  Set Scene 'Barn General Fade' Off
                  No Actions.
The is not will make the Off program quit if during the Wait the motion sensor switches on again.
I find it useful to use two different scenes. The On scene would have short ramp rates and the Off uses long ramp rates. Then the lights fading will give you a chance to make motion again.
It's also better to watch for Control from a motion sensor as they cannot be Queried for Status unless they are in linking mode.
Rand
I also took a secondary (no-load) switch in our kitchen out of the motion scenes. I added a line that checks that it's Status must be Off or neither program runs. So turning on the lights with that switch will require turning them off with that switch or a linked switch or using another program or direct control. A KPL button can be used as well.
Add this to your Conditions (Add to 'If') if you like:
   And Status  'Barn On Switch' is Off
Rand
