Multiple ISY's
Hi,
I have 3 locations and an ISY in each.  I also have a couple of Google Home units in each location.  I use the same google account all locations. I don't see a way to add more than 1 ISY.  Is there?  Or do I need to start using separate google accounts for each location?
Paul
Hi,
Paul
I have two ISYs at two different locations. I wanted to keep them separate so they both have their own ISY portal. We use Amazon Echos, so I have separate Amazon accounts for both.
Agave and MobiLinc both support mutiple accounts. So each location has its own account in each.
Sent from my XT1650 using Tapatalk
Hi Paul,
You need an ISY Portal module for each. This might help as the concept is the same:
http://wiki.universal-devices.com/index.php?title=ISY_Portal_Amazon_Echo_Integration#Instructions_for_using_Multiple_ISYs_with_one_Echo_Accout
Michel,
I have multiple isy accounts (although I have been tracking down another problem with you even today).
Issue is I see no way to have google home to add automation from multiple account.
Paul
