Add a second Elk to the ISY
I've asked this in the Elk sub-forum, but got no response, so I'll ask here.
I've got an Elk M1 and the ISY in my home with the Elk module installed. They work together flawlessly. I also have an Elk M1 in my rental house next door. That panel is connected to the same network my ISY is on. Is there a way to add the second Elk to communicate with the ISY?
You will probably need a second Elk module.
Sent from my SM-G955U1 using Tapatalk
