Quick programming question
I am a network geek, and programming hurts my brain...
Here is what I have in the 99i controlling a SHN EZFlora Irrigation Controller:
On Mon, Fri
From Sunrise
For 10 minutes
Set xx.xx.xx On
No Action
This works fine, but after the 10 minutes, the zone still shows on. Do I need to add more to this so that the zone turns off. Technically the zone gets a single run command that includes the time, so I don't need to turn it off, but for accuracy I would like it to reflect the current state the zone is in.
Thanks! I just did that, next run is Mon so I will see what happens then.
