Brighten then go back
MIlton
Hey all,
My ISY994 has been rock solid for a few years now.
I have about 30 insteon devices around the house.
Trying to tighten up home security a bit but struggling.
I have several motion sensors around the property.
When one triggers its set to turn a scene on that includes security lights.
Unfortunately when the motion sensor turns off,  it also turns off all the lights in the scene.
This is really a pain when the whole house lighting is set nicely and then a bunch of lights turn off for good.
Is there a way to create a program that will trigger on motion, check the level of each device, brighten everything for a time, then set everything back to where it was?
I have some neat programs but this is one thing I just could not figure out.
I cant find a way to set a variable to the current level of a device =-(
Any advice or ideas here would be awesome!
Milt
My understanding is this is possible in v5? If running v4 (I am) then I believe it’s too cumbersome since you would need to check every lights status from 0 to 100% and then stuff that into a variable. I tried to do the same thing here so if I’m wrong someone please chime in!
I'm under the same impression, namely, that v5+ is needed to store the On-Level for each device. But, if the OP has a usual On-Level (I do), then only that level needs to be reset. So for example, our living room is normally at 20% and the kitchen at 50%, then I need only restore those levels. The same goes for other lights that are normally on during the late evening and early night.
Thanks everyone for the responses!  So it seems that unless I go with the Alpha software 5+ there is no easy way to do this now with 4.6.2?
It seems like it should be so easy to set a variable to a devices current state or level.
I must really be missing something here I suppose, and someone must have found a way to get around the motion sensors turning off all the lights after motion is detected.
ANy other thoughts or help would be most appreciated!-Milt
Have you ever coded? If so, then what's the easy solution. BTW, an actual solution was posted; See post #3. See, it really is easy, but a bit tedious B)
      38k
      379.3k
