2476D V4.5 Crazy Behavior
1 hour ago, apostolakisl said:
Just did the same repair to a KPL.  It had failed as if it were getting no power.  I opened it up to see what caps it might have, and it has the same cap.  I replaced that one capacitor and the KPL is back up and running.
Again, I wish there were away to rivet the heat sink back to the body.  Any ideas?
Lots of heat conductive silicone grease and small bolt, lock, and nut?
I was going to try a pop-rivet -- I found an aluminum rivet of the correct outside diameter.  Perhaps I should dig up that KPL and see if that works.
It would require just the most perfect rivet since there isn't much clearance on the inside or outside.
  • 6 months later...
Standard aluminum rivets worked fine on the 2 switches I repaired last year.  I have 4 more to do now - most are 8 - 10 yrs old, so I guess I was lucky.  Some were doing the weird stuff like above, a couple were just dead.  I fixed 2 keypad lincs the same way, replacing the caps with low esr caps.  I have only had one not work by replacing caps.  Also repaired a PLM the same way.
      37.5k
      375k
