ISY not responding
ISY is not responding via Alexa and MobilLinc App. Can access ISY locally.
Same here, it was working around 630am PT this morning, it's not working now.
Can log into my.isy.io, but when trying to have the portal connect via ISY web access, or pull up the log, it fails.
Edited by toddhutch
Michel,
Could you please unpin some of the older update stickies from the forum?  Ones from two years ago are probably stale by now
My portal account says "Offline since Friday, February 16th, 8:24:10 AM "  if that helps ???   Alexa responds " the hub is not responding" etc.
any help will be much appreciated, thanks
All seems to be working now.  Thanks for your prompt attention to the matter
Still having issues with Alexa and Google home. The last few days it is been delayed but today it just will not work.
Voice commands, web access not agave work right now. The ISY was rebooted this morning.
  • 3 months later...
I just signed up fro portal.
All I get is error ISY not online.
I can access it fine from mobilinc and admin screen
If you are using the Mobilinc portal, you cannot use the UDI portal. It needs to be one or the other. If you choose the UDI portal you can still use Mobilinc by connecting to your ISY and not using the Mobilinc portal.
Well I have a long term subscription to MobiLinc.
So how do I get Alexa to discover sprinklers without ISY portal?
