February 21, 20188 yr I have several Zwave door sensors and recently I get this error message, basically all the time. Initially I believed that it was the battery which I changed (and shows 100%), but still the same message. However the door sensor DOES work in its programs, so when I need it, it communicates. What could be the cause of this issue ?
February 22, 20188 yr I was experience the same since upgrading to 5.0.11C. If you watch the level 3 log it looks like the device wakes up, the ISY puts it to sleep but then tries to communicate with it. If you turn off the put devices to sleep zwave option, that fixes it. Although that's not an ideal solution. I was going to post a log but haven't had a chance.Sent from my Pixel 2 XL using Tapatalk
February 22, 20188 yr Author 38 minutes ago, Jimbo said: I was experience the same since upgrading to 5.0.11C. If you watch the level 3 log it looks like the device wakes up, the ISY puts it to sleep but then tries to communicate with it. If you turn off the put devices to sleep zwave option, that fixes it. Although that's not an ideal solution. I was going to post a log but haven't had a chance. Sent from my Pixel 2 XL using Tapatalk Thanks Jimbo. I will try this. Maybe the UDI team can have a look at this. Edited February 22, 20188 yr by asbril
February 22, 20188 yr 57 minutes ago, Jimbo said: I was experience the same since upgrading to 5.0.11C. If you watch the level 3 log it looks like the device wakes up, the ISY puts it to sleep but then tries to communicate with it. If you turn off the put devices to sleep zwave option, that fixes it. Although that's not an ideal solution. I was going to post a log but haven't had a chance. Sent from my Pixel 2 XL using Tapatalk Does turning off put device to sleep mean that the battery is always in use. If so, then it's not only is it not an ideal solution, it's a terrible solution. OTOH, if it does not mean that the battery is always in use, then the solution is OK.
February 22, 20188 yr 2 minutes ago, stusviews said: Does turning off put device to sleep mean that the battery is always in use. If so, then it's not only is it not an ideal solution, it's a terrible solution. OTOH, if it does not mean that the battery is always in use, then the solution is OK. No, it means the device goes back to sleep on it's own, which is usually pretty quickly, instead of the ISY putting back to sleep immediately.
February 22, 20188 yr 27 minutes ago, asbril said: Thanks Jimbo. I will try this. Maybe the UDI team can have a look at this. Not sure which ones you have, but it's happening with my Aeotec Door/Window ZW089-2 and ZW112-A's at my lake house, and did not seem to be happening with my ZW097-A dry contact sensors at home.
February 22, 20188 yr Author 10 minutes ago, Jimbo said: Not sure which ones you have, but it's happening with my Aeotec Door/Window ZW089-2 and ZW112-A's at my lake house, and did not seem to be happening with my ZW097-A dry contact sensors at home. What brand are your dry contact sensors ?
February 22, 20188 yr Hello everyone, We are looking into what @Jimbo outlined. With kind regards, Michel
