Bumbershoot Posted October 13, 2019 Share Posted October 13, 2019 57 minutes ago, gviliunas said: I just noticed that the battery level ( % ) parameter is blank for all of my tags Hi, I just rebooted my ISY, reloaded by AC and I'm now missing the battery level values as well. The ISY is getting battery data (see screenshot of the event viewer -- CV value of 299), but it's not showing in the AC. EDIT: It appears that the BATLVL value isn't seen in the data. I'll watch for it and wait to see if it populates when the data changes. <!-- Tag 13 C --> <nodeDef id="wTag13C" nls="tag13"> <editors /> <sts> <st id="ST" editor="BOOL" /> <!-- Status, online? --> <st id="GPV" editor="I_TAGID" /> <!-- TagId (SlaveId) --> <st id="GV1" editor="I_TAGTYPE" /> <!-- TagType --> <st id="GV13" editor="I_INTEGER" /> <!-- Time --> <st id="GV14" editor="I_INTEGER" /> <!-- Seconds since update --> <st id="GV8" editor="BOOL" /> <!-- Out Of Range --> <st id="CC" editor="SIGDBM" /> <!-- signaldBm --> <st id="ALARM" editor="I_EVST" /> <!-- Event State --> <st id="GV7" editor="I_LIT" /> <!-- Light --> <st id="CLITEMP" editor="I_TEMP_C" /> <!-- Temperature --> <st id="CLIHUM" editor="I_HUM" /> <st id="BATLVL" editor="BATLVL" /> <!-- Battery Percentage --> <st id="CV" editor="FLOAT" /> <!-- Battery Voltage --> <st id="GV2" editor="I_MOTION" /> <!-- Motion --> <st id="GV3" editor="FLOAT" /> <!-- Orientation --> <st id="GV4" editor="FLOAT" /> <!-- X-Axis --> <st id="GV5" editor="FLOAT" /> <!-- Y-Axis --> <st id="GV6" editor="FLOAT" /> <!-- Z-Axis --> <st id="GV9" editor="I_TMST" /> <!-- Temperature State --> <st id="GV10" editor="I_CPST" /> <!-- Moisture State --> </sts> <cmds> <sends /> <accepts> <cmd id="SET_LIGHT"> <p id="" editor="I_LIT" init="GV7" /> </cmd> <cmd id="SET_URL_CONFIG" /> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 13, 2019 Share Posted October 13, 2019 Okay, I just forced a test of the battery level in one of my tags by replacing a battery. The "Battery Level" value did not populate, while the "Battery Voltage" value updated. Given that, it appears that the OP is correct. Link to comment Share on other sites More sharing options...
gviliunas Posted October 14, 2019 Share Posted October 14, 2019 Thanks for checking this @Bumbershoot I'll keep watching and verify that this is nothing to worry about. Greg Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted October 14, 2019 Author Share Posted October 14, 2019 Thanks guys, Sounds like I need to take a look at it. I haven't done the ISY upgrade yet.Sent from my Pixel 3 XL with Tapatalk Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted October 19, 2019 Author Share Posted October 19, 2019 On 10/13/2019 at 11:06 AM, gviliunas said: Battery Level parameter is blank for all Tags I just noticed that the battery level ( % ) parameter is blank for all of my tags. Previously, I have used this parameter to report low battery levels in the tags via ISY programs. ISY is now reporting low battery in all the tags. The admin console shows battery voltage present as are the other parameters. The other parameters seem to be updating properly. Just Battery Level is blank. Tried to download a log but nothing happens when I click to download the log or log package. Tried to Query the tags individually and tried a Discover in the tag manager page. Finally, restarted Polyglot and ISY - No change in symptoms I recently upgraded to: Polyglot v2.2.3, Wireless Tag NS v2.0.9, ISY 5.0.16 Fixed in 2.0.10, should be in the store within an hour. https://github.com/jimboca/udi-wirelesstag-poly#upgrading Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 19, 2019 Share Posted October 19, 2019 11 hours ago, Jimbo said: Fixed in 2.0.10, should be in the store within an hour. https://github.com/jimboca/udi-wirelesstag-poly#upgrading Confirmed here. Thanks. Link to comment Share on other sites More sharing options...
gviliunas Posted October 20, 2019 Share Posted October 20, 2019 Thanks @Jimbo, Yes, battery level is now present for all my tags! Link to comment Share on other sites More sharing options...
ulrick65 Posted October 23, 2019 Share Posted October 23, 2019 I really like the sounds of these little sensors and setting them up through ISY. I am curious though if anyone here can post some "use case" info for them....in other words, how many do you have and what are you using them for? Might give me some additional ideas beyond simply wanting to measure temp and humidity in my bedroom for example. Thanks. Link to comment Share on other sites More sharing options...
larryllix Posted October 23, 2019 Share Posted October 23, 2019 1 hour ago, ulrick65 said: I really like the sounds of these little sensors and setting them up through ISY. I am curious though if anyone here can post some "use case" info for them....in other words, how many do you have and what are you using them for? Might give me some additional ideas beyond simply wanting to measure temp and humidity in my bedroom for example. Thanks. Fridge door open too long and temperature deviation of fridge failure Garage door open/closed detection plus garage temperature Wine cellar temp and humidity control via ventilation Vehicle nearby/ garage door left open notifications plus temperature in glove department. Outside weather on cold wall and solar influenced wall for predictive thermostat overshoot, early shutdown, compensated by Lux detection with newer Tags Router overheating HVAC heating zone setup, overshoot detection, and thermostat calibration HVAC duct temperature for air flow balancing Humidistat sensor calibration between multiple units Link to comment Share on other sites More sharing options...
GlowingHair Posted October 23, 2019 Share Posted October 23, 2019 8 hours ago, ulrick65 said: I really like the sounds of these little sensors and setting them up through ISY. I am curious though if anyone here can post some "use case" info for them....in other words, how many do you have and what are you using them for? Might give me some additional ideas beyond simply wanting to measure temp and humidity in my bedroom for example. Thanks. In addition to Larry's list, I use the tags in my city waste bins (trash, recycle, yard) so I know when they have been picked up. The trucks vary their routes from time to time, and it saves a walk (or fall) down my steep driveway in the winter just to discover the truck is going to be later than usual. Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 23, 2019 Share Posted October 23, 2019 10 hours ago, ulrick65 said: I really like the sounds of these little sensors and setting them up through ISY. I am curious though if anyone here can post some "use case" info for them....in other words, how many do you have and what are you using them for? Might give me some additional ideas beyond simply wanting to measure temp and humidity in my bedroom for example. Thanks. Humidor temp/humidity/open/closed Crawl space and attic temp/humidity Occupancy Soil moisture content BBQ internal temp Lots of tags varieties and capabilities means that the limit is your imagination. There are ways to monitor all of the above with other devices and your ISY, but these work, are relatively inexpensive, have good range and battery life, and are relatively unobtrusive. Link to comment Share on other sites More sharing options...
larryllix Posted October 23, 2019 Share Posted October 23, 2019 1 minute ago, Bumbershoot said: Humidor temp/humidity/open/closed Crawl space and attic temp/humidity Occupancy Soil moisture content BBQ internal temp Lots of tags varieties and capabilities means that the limit is your imagination. There are ways to monitor all of the above with other devices and your ISY, but these work, are relatively inexpensive, have good range and battery life, and are relatively unobtrusive. Can you elaborate on your occupancy usage? Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 23, 2019 Share Posted October 23, 2019 Just now, larryllix said: Can you elaborate on your occupancy usage? Sure. I use a PIR sensor in the master bathroom to start a timer for turning off the lights after a certain period of no occupancy. It also measures humidity and temp. There are a bunch of other capable devices for this purpose, but this little tag gets past the critical eye of the head interior designer of the house. I also use them to turn on the deck and back yard lighting when we let the dog out. Lots of coyotes where I live... Link to comment Share on other sites More sharing options...
larryllix Posted October 23, 2019 Share Posted October 23, 2019 27 minutes ago, Bumbershoot said: Sure. I use a PIR sensor in the master bathroom to start a timer for turning off the lights after a certain period of no occupancy. It also measures humidity and temp. There are a bunch of other capable devices for this purpose, but this little tag gets past the critical eye of the head interior designer of the house. I also use them to turn on the deck and back yard lighting when we let the dog out. Lots of coyotes where I live... Thanks. I forgot about the PIR sensor and have none. Yeah, dogs don't do well against a pack of coyotes at night. Our cats did well up until last year one came home mangled and now a few have disappeared. The litter has grown though. We get them right in our side yard but blinking the lights makes them disappear for a few hours, so far. In the spring a fellow builder down the street had a stand-off with one during the daylight. Link to comment Share on other sites More sharing options...
lilyoyo1 Posted October 23, 2019 Share Posted October 23, 2019 32 minutes ago, Bumbershoot said: Sure. I use a PIR sensor in the master bathroom to start a timer for turning off the lights after a certain period of no occupancy. It also measures humidity and temp. There are a bunch of other capable devices for this purpose, but this little tag gets past the critical eye of the head interior designer of the house. I also use them to turn on the deck and back yard lighting when we let the dog out. Lots of coyotes where I live... Which PIR sensor are you using Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 23, 2019 Share Posted October 23, 2019 4 minutes ago, lilyoyo1 said: Which PIR sensor are you using PIR KumoSensor. I've had them outside (though covered and out of the moisture) for over 18 months. I only enable them during certain hours to save battery life. They seem to do the job. Link to comment Share on other sites More sharing options...
lilyoyo1 Posted October 23, 2019 Share Posted October 23, 2019 13 minutes ago, Bumbershoot said: PIR KumoSensor. I've had them outside (though covered and out of the moisture) for over 18 months. I only enable them during certain hours to save battery life. They seem to do the job. Thanks. I've been wanting to try other sensors to see how they work Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 23, 2019 Share Posted October 23, 2019 16 minutes ago, lilyoyo1 said: Thanks. I've been wanting to try other sensors to see how they work They're pretty good. Maybe not quite as reliable as an entirely local solution Iike Z-Wave or Insteon, but I can't sell the Mrs. on placing those hulking big barnacles all over the house. These are much more discreet, at least in her eyes. Link to comment Share on other sites More sharing options...
lilyoyo1 Posted October 23, 2019 Share Posted October 23, 2019 13 minutes ago, Bumbershoot said: They're pretty good. Maybe not quite as reliable as an entirely local solution Iike Z-Wave or Insteon, but I can't sell the Mrs. on placing those hulking big barnacles all over the house. These are much more discreet, at least in her eyes. I'm wanting to go smaller as well. The some and fibaro units are probably the smallest but if I can get smaller it's even better. Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 23, 2019 Share Posted October 23, 2019 10 minutes ago, lilyoyo1 said: I'm wanting to go smaller as well. The some and fibaro units are probably the smallest but if I can get smaller it's even better. I would NOT use these in a mission critical application, such as lighting a dark staircase upon occupancy, but I'm sure you understand that. Link to comment Share on other sites More sharing options...
lilyoyo1 Posted October 23, 2019 Share Posted October 23, 2019 41 minutes ago, Bumbershoot said: I would NOT use these in a mission critical application, such as lighting a dark staircase upon occupancy, but I'm sure you understand that. I use my sensors mostly to turn stuff off vs turning them on. The few locations I automatically turn on are completely dark places like closets, my half baths, and flood lights Link to comment Share on other sites More sharing options...
ulrick65 Posted October 23, 2019 Share Posted October 23, 2019 Thanks for all the feedback..I really appreciate it and will give them a go for some uses. @Bumbershoot You use them inside a barbeque? How does that work without melting...I did not think they could take that kind of heat? Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 23, 2019 Share Posted October 23, 2019 32 minutes ago, ulrick65 said: You use them inside a barbeque? Look at the Outdoor Probe fitted with a thermocouple. Insert the thermocouple end into the BBQ. Link to comment Share on other sites More sharing options...
ulrick65 Posted October 23, 2019 Share Posted October 23, 2019 11 minutes ago, Bumbershoot said: Look at the Outdoor Probe fitted with a thermocouple. Insert the thermocouple end into the BBQ. Ah ha! Tricky! Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 29, 2019 Share Posted October 29, 2019 I'm getting the following error this morning after upgrading to the new Polyglot versions (both on the RPi version - 2.2.5, as well as on the Polisy version - 2.2.5): Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/nodeservers/WirelessTag/wt_nodes/wTagManager.py", line 298, in _set_url_config_false self._set_url_config(force=False) File "/var/polyglot/nodeservers/WirelessTag/wt_nodes/wTagManager.py", line 312, in _set_url_config tag.set_url_config(force=force) File "/var/polyglot/nodeservers/WirelessTag/wt_nodes/wTag.py", line 246, in set_url_config param = def_param NameError: name 'def_param' is not defined EDIT: This does not appear to be a fatal error. The nodeserver continues to run. Link to comment Share on other sites More sharing options...
