March 18, 20188 yr Hi. Do you guys know if all features of this plug in are supported? ZooZ Z-wave Plus Smart Plug Thanks.
March 18, 20188 yr I have a couple. They are supported. https://www.monoprice.com/product?p_id=27481 Edited March 18, 20188 yr by Harvvm
June 10, 20196 yr have anyone tried the Zooz Zen 25? Is has great features, but I keep getting reliability issues depending on how the ISY perceives the device. It appears to pick up phantom nodes and when trying to communicate to them it will lose communication with the entire module some times.
August 12, 20196 yr On 6/9/2019 at 11:15 PM, Randy Ide said: have anyone tried the Zooz Zen 25? Is has great features, but I keep getting reliability issues depending on how the ISY perceives the device. It appears to pick up phantom nodes and when trying to communicate to them it will lose communication with the entire module some times. Did you ever try the ZEN 25? I am looking at the ZEN26 and ZEN27. Figured if the ZEN25 worked then I may be in good shape.
August 13, 20196 yr On 3/18/2018 at 3:52 PM, Harvvm said: I have a couple. They are supported. https://www.monoprice.com/product?p_id=27481 I'm having issues with the same Monoprice Smart Plugs. They are not updating UI status in Admin Console (also in Agave app) when I control device manually. Does it work for you? Do you see status changes in the Admin Console when you manually turn the plug on/off? Thanks!
August 13, 20196 yr 39 minutes ago, fmark said: I'm having issues with the same Monoprice Smart Plugs. They are not updating UI status in Admin Console (also in Agave app) when I control device manually. Does it work for you? Do you see status changes in the Admin Console when you manually turn the plug on/off? Thanks! I don't see anything in their literature that says it has instant status. I would contact monoprice to see if it does.
August 13, 20196 yr 22 minutes ago, lilyoyo1 said: I don't see anything in their literature that says it has instant status. I would contact monoprice to see if it does. I don't know of any Zwave Plus device that does not have instant reporting.
August 13, 20196 yr 30 minutes ago, lilyoyo1 said: I don't see anything in their literature that says it has instant status. I would contact monoprice to see if it does. It works perfectly with SmartThings - status in the App gets updated immediately.
August 13, 20196 yr On 6/10/2019 at 2:15 AM, Randy Ide said: have anyone tried the Zooz Zen 25? Is has great features, but I keep getting reliability issues depending on how the ISY perceives the device. It appears to pick up phantom nodes and when trying to communicate to them it will lose communication with the entire module some times. I get these phantom nodes with my ISY for lots of devices not just the Zooz devices. I have lots of the ZEN15 and ZEN20 devices and every now and again a "Color Light" is associated with one of them. I've had a weird effect that I noticed today where a child of the ZEN20 (powerstrip) plug 2 that is turned on/off by a program only was showing "On" in the Admin Console but when I queried it then changed to "Off" which is what it should have been. Not sure why the AC was showing it as on when it was off and the only control is from the ISY.
August 13, 20196 yr 1 hour ago, asbril said: I don't know of any Zwave Plus device that does not have instant reporting. I don't either. However with the amount of devices out there and different features they support, it's something I always verify.
