unable to add zwave switch GE 14291
I"ve been trying to add a zwave switch to my device for a day or so.
I believe I've done everything per procedure. First exclude / remove 2x than add. Ultimately the device never shows up on my device tree.
At one point I had something show up but it showed as unresponsive / uninitialised.
This is what the log says after one of the iterations.
Mon 03/26/2018 08:03:25 PM : Listening for Z-Wave devices to add to the network
Mon 03/26/2018 08:03:25 PM : [ZWAVE-RX        ] [0107004A18020000]...
Mon 03/26/2018 08:03:25 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:03:25 PM : Z-Wave device detected, retrieving info 2
Mon 03/26/2018 08:03:26 PM : [ZWAVE-RX        ] [0118004A18030211]...
Mon 03/26/2018 08:03:26 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:03:26 PM : Z-Wave device detected, retrieving info 3
Mon 03/26/2018 08:03:33 PM : [ZWAVE-RX        ] [0107004A18050200]...
Mon 03/26/2018 08:03:33 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:03:33 PM : Z-Wave device detected, retrieving info 5
Mon 03/26/2018 08:03:34 PM : [ZWAVE-TX        ] [0105004A85192C]
Mon 03/26/2018 08:03:34 PM : [ZWAVE-RX        ] ACK
Mon 03/26/2018 08:03:34 PM : [ZWAVE-RX        ] [0107004A19060200]...
Mon 03/26/2018 08:03:34 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:03:34 PM : Adding Z-Wave devices stopped
Mon 03/26/2018 08:03:34 PM : [ZWAVE-TX        ] [01030020DC]
Mon 03/26/2018 08:03:34 PM : [ZWAVE-RX        ] [01080120C00511C1]...
Mon 03/26/2018 08:03:34 PM : [ZWAVE-TX        ] [01030002FE]
Mon 03/26/2018 08:03:34 PM : [ZWAVE-RX        ] [0125010205001D03]...
Mon 03/26/2018 08:03:34 PM : [ZWAVE-TX        ] [01030005F9]
Mon 03/26/2018 08:03:34 PM : [ZWAVE-RX        ] [0104010508F7]
Mon 03/26/2018 08:03:34 PM : Device 2 of type 4.16.1 included into Z-Wave network
Mon 03/26/2018 08:03:34 PM : [ZWAVE-TX        ] [0109001302027204]...
Mon 03/26/2018 08:03:34 PM : [ZWAVE-RX        ] [0104011301E8]
Mon 03/26/2018 08:03:38 PM : [ZWAVE-RX        ] [010500131A01F2]
Mon 03/26/2018 08:03:38 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:03:39 PM : [ZWAVE-TX        ] [0109001302027204]...
Mon 03/26/2018 08:03:39 PM : [ZWAVE-RX        ] ACK
Mon 03/26/2018 08:03:39 PM : [ZWAVE-RX        ] [0104011301E8]
Mon 03/26/2018 08:03:39 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:03:43 PM : [ZWAVE-RX        ] [010500131A01F2]
Mon 03/26/2018 08:03:43 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:03:44 PM : [ZWAVE-TX        ] [0109001302027204]...
Mon 03/26/2018 08:03:44 PM : [ZWAVE-RX        ] ACK
Mon 03/26/2018 08:03:44 PM : [ZWAVE-RX        ] [0104011301E8]
Mon 03/26/2018 08:03:44 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:03:49 PM : [ZWAVE-RX        ] [010500131A01F2]
Mon 03/26/2018 08:03:49 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:03:49 PM : Cannot get manufacturer specific data
After this I believe I excluded again 2x and then after a re-add I got this:
Mon 03/26/2018 08:12:39 PM : [ZWAVE-TX-NR     ] [0105004AC12352]
Mon 03/26/2018 08:12:39 PM : [UZW-CMD 1       ] Start Include
Mon 03/26/2018 08:12:39 PM : [ZWAVE-RX        ] ACK
Mon 03/26/2018 08:12:39 PM : [ZWAVE-RX        ] [0107004A23010000]...
Mon 03/26/2018 08:12:39 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:12:39 PM : Listening for Z-Wave devices to add to the network
Mon 03/26/2018 08:15:13 PM : [        Time] 20:15:20 0(0)
Mon 03/26/2018 08:17:07 PM : [ZWAVE-RX        ] [0107004A23020000]...
Mon 03/26/2018 08:17:07 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:17:07 PM : Z-Wave device detected, retrieving info 2
Mon 03/26/2018 08:17:10 PM : [ZWAVE-RX        ] [0107004A23070000]...
Mon 03/26/2018 08:17:10 PM : [ZWAVE-TX        ] ACK
Mon 03/26/2018 08:17:10 PM : Adding Z-Wave devices stopped
Mon 03/26/2018 08:17:10 PM : [ZWAVE-TX        ] [01030020DC]
Mon 03/26/2018 08:17:10 PM : [ZWAVE-RX        ] ACK
Mon 03/26/2018 08:17:10 PM : [ZWAVE-RX        ] [01080120C00511C1]...
Mon 03/26/2018 08:17:10 PM : [ZWAVE-TX        ] [01030002FE]
Mon 03/26/2018 08:17:10 PM : [ZWAVE-RX        ] [0125010205001D01]...
Mon 03/26/2018 08:17:10 PM : [ZWAVE-TX        ] [01030005F9]
Mon 03/26/2018 08:17:10 PM : [ZWAVE-RX        ] [0104010528D7]
Mon 03/26/2018 08:17:10 PM : Z-Wave device detected, retrieving info 7
Mon 03/26/2018 08:25:11 PM : [        Time] 20:25:19 0(0)
Any tips or help appreciated. I'm not having much success.
Thanks for the quick reply.
Before I posted I had factory reset the device 2x as well. I was about 15 feet away I'll attempt to get a little closer and try again.
Edited by dvandorp
I uploaded 5.0.12 firmware AND went three feet from the device and the switch added first try!
Next issue is I moved the isy back to the basement and now it appears it's out of range. :(
Perform a Heal
1 hour ago, dvandorp said:
Yes it is.
Sent from my Pixel XL using Tapatalk
You need more devices between the ISY and switch. Building a strong mesh network is paramount for good communication. I've attached a link from another zwave post that you should read.
https://drzwave.blog/2017/01/20/seven-habits-of-highly-effective-z-wave-networks-for-consumers/
25 minutes ago, asbril said:
Perform a Heal
A network heal wouldn't work for him in this case since he only has 1 device.
Edited by lilyoyo1
lilyoyo1 : you are absolutely right .
FWIW, I have a couple of those switches and can confirm they work with the ISY.
Range or defect would be my guess as to your issue.
I was able to add the device. Range definitely seems to be the issue.
In for a penny in for a pound. More zwave devices on order.
So, at the end of the day my other zwave devices arrived. I had a heck of a time getting them added and communicating with the ISY. I ended up getting a Aeotec Zwave stick and setting up homeassistant to control it and worked out ok. My goal was to ultimately setup the isy as a secondary controller but never got that working either.
I love my isy with insteon but really had trouble with zwave.
I would get an old extension cord, add the devices while close to the ISY and then move them to their permanent location. Once finished, run a network heal. This is how I handle all of my Insteon and zwave devices.
