Fibaro KeyFOB FGKF-601
I got a Z-wave Fibaro KeyFOB FGKF-601 and i can add it to ISY, and run VERY limited couple of buttons in a program.
(PDF manual and photo are attached below...)
After adding, it then showing a bunch of nodes:
ZW 014 Wall Controller
ZW 014 Scene Button 1 (to 14... so 14 rows)
ZW 014 Low Battery 1
Then, after programming and over time... pushing various buttons, it added:
ZW 014 Multilevel Switch 3
ZW 014 Multilevel Switch 5
ZW 014 Multilevel Switch 7
ZW 014 Multilevel Switch 9
ZW 014 Multilevel Switch 11
Is there any hope to get this added into ISY properly? @Michel Kohanim?
It seems to be fairly highly respected (Fibaro)...
It sure would be nice to have the 30plus functions it is supposed to do...
(even 12 or 18 or 24??)
Fred
FGKF-601-EN-T-v1.1.pdf
Edited by johnstonf
What firmware are you running? Make sure you are on 5.0.12 if you want to use multi channel devices. With that said, from reading the manual, the functions are enabled by setting the parameters that you want to use in the isy.
i have 5.0.12, but beyond that I'm not sure how to set up parameters...
Right click on the device, you'll see zwave at the bottom click on where it says parameters. You'll then follow the manual and input whatever parameters you want to use to achieve your desired result
To explain a little further...
I created a YouTube video of setup with ISY...
-It doesn't show the 6th button
-I was able to get parameters to the KeyFob, but it's only for basic functions (what the keypresses do)
-It sets up strangely (it shows a bunch of nodes, then adds more as buttons are pressed
To me, it seems like the ISY isn't doing something right in the process.
Fred
Hi Fred,
Thanks for the video. Functions that are described during inclusion are manufacturer specific and usually require setting up parameters as you have done. The only hope is to get one of these and see what we can do with it.
Seems like a really nice, light (hang around neck on a lancer etc) with lots of functions if we can get it working with isy. They mention multi-nodes support and that it should work with any z-wave controller.
What would cause nodes to change once they have been included, and inclusion mode is no longer being ran?
Fred
So how would you interpret that only the 6th button is not creating a node, but i do see the TX/RX lights flash away when i press the button?
Attached is what i got on the log (event viewer) when pressing button#6
Edited by johnstonf
1 hour ago, Michel Kohanim said:
Hi Fred,
I don't know. That's why we ordered one to test. This said, however, it seems that the key = 6. So, the question is whether or not you get key = 6 for any other events.
Hi Fred,
Oh great you ordered one!
Look forward to you investigating it!
Thanks, Fred
Fred
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
