Can I Perform Such Calculations?
Attached is a picture of a calculation that I'd like to use to trigger specific programs. Is it possible? If yes, how? dd78631eb7689b49ee584d5607fb55e6.jpg
Sent from my SM-G930T using Tapatalk
I don't know what 12 A could possibly mean but all basic math is possible in ISY.
For the remainder it is called modulo
$variable %= 12
For the integer of the division use.
$variable /= 12
Sent from my SM-G930W8 using Tapatalk
$variable %= 12
$variable /= 12
As stated in the equation
A=The Jewish Year which this year is 5778
5778 what?
It's simple algebra pluging in the values to solve the equation. The question is does it work with ISY? If yes how?
Yes but it would need to be known what the result you want is.
5778 what?
Did you want the whole number portion and fractional parts in different variables M and m?
Will A be changing each year and will it be used again?
5778 what?
A will be changing each year
Here's the other other half of the equation. Sorry.
Here's the other other half of the equation. Sorry.603269b45b7cf53d1e6c1704dbb50ddb.jpg
I don't have access to my ISY right now but what I would is define a State variable for each variable in the formula.
Then I would create a program for each variable with a trigger condition for each variable involved in the program like this
.....$var1 ....or
.... $var2
....program to calc that variable
Now when any value is changed the programs will self trigger and calculate each result into it's variable in a chain reaction.
The decimals will have to set for each variable minding overflow quantities at 32 bit values.
Hi [mention=9795]ElectricCPR[/mention],
Yes, it's doable.
How? I tried the remainder function and it doesn't seem to work!
I have had no problem with the modulo operator.
What does "It does not work" mean?". "The answer is always 0"?, "the answer is incorrect"? "The answer never changes from the original quotient"? "The answer is not what I  expected"?
Let's work from there so you can understand how ISY works possibly.
What was your test program. You can right click on your program and use "copy to clipboard"  and then paste it here for more help.
It may take a dozen or so variables and ~20 lines of code but can be done. If some of the values you have in parentheses are true constants then you will want to precalculate them.
Luckily, the formula can be broken down and each operation done easily. God forbid you needed any trigonometry functions or anything more advanced.
The modulo works here:
New Program - [ID 0029][Parent 0010]
        $Int_41  = 18
        $Int_41 %= 4
Result - $Int_41 = 2 (18%4)
Edited by DrLumen
I was testing the module not with this equation, but in general. What I'm trying to accomplish is:
$Days_Till_RH is 0
And Time is 1:00:00AM
Wait 25 hours
$Jewish_Year += 1
$Jewish_Year Init To $Jewish_Year
Wait 5 seconds
Adjust program Pesach Trigger
PS I just realised that I can't set it to trigger on a specific date if there is a way please let me know
There are some options to baseline your programs to the actual date:
  • If you want to run the V4 family of ISY Firmware, you can set up the isylink program on an external computer and it can be configured to load month, day and year into separate ISY variables. You can work with that in your program.
  • If you are willing to run the V5 family of ISY Firmware, there are enhancements to its admin console and program/variable features to use month, day and year in variables
Paul
  • 1 year later...
After putting time into it, finally wrote the code and tested it. I'm sure that it can be revised to make it shorter, but it works!!!! PM me if you're interested in it
