Multiple BE469s
I have had a working BE469 for several months (door to garage).  Worked fine and paired fine about 20’ from ISY.  I would like to install another one on the outer door which is about 20’ past the first one and set it up so that a specific code entered outside also unlocks the inner lock as a responder.
My reservations are:
1- will the first lock act as a repeater since the second lock will be 40+ feet from isy?
2- can I make one code unlock both locks and other codes only work on the outer lock?
The other problem is that the current lock went on the fritz and I haven’t been able to get it to correctly pair.  Will try a factory reset later this week when I get back home.
Battery powered devices do not repeat signals so a lock will not work for repeating.
Yes, if you write a program that unlocks the second lock it will do so.
