Sony API added to ISY
Welcome to the forums!
You could likely send the proper codes using the ISY Network Resources Module. It's a built in software module that is enabled witha code costing about $40  IIRC. It also comes included in a bundle with the ISY portal that can run on a RPi for interfacing with Alexa and Google Home vocal inputs.
The NR module can output almost any Ethernet protocol and each sequence can be user names so your ISY code reads sanely.
