Unable to link Universal Devices to Google Home
Hi, I'm subscribed to ISY Portal and had to unlink my account from Google Home because I added a couple of new devices that were not showing up. I tried to re-link my Portal account through the Google Assistant app, but when I enter my email and password for ISY Portal, I get an error page showing code 401, "Your client does not have permission to the requested URL." I can log in directly to the ISY Portal using the same credentials. How can I resolve this issue?
Well, of course I find a solution shortly after posting the question. In case someone else encounters this same issue... I had both the Google Home iOS app and the Google Assistant iOS app installed on my phone. When I clicked on the Home Control section in Google Home, it kicked me off to the Assistant app to finish the linking process. This is where the authentication failure happened. I uninstalled the Assistant app and tried again. This time the Google Home app pulled up the ISY Portal login page. Entering my credentials there worked correctly.
  • 4 months later...
When trying to link my google home to the ISY portal I keep getting the below screen then nothing happens.
What should I see next?
I kept getting the same message that @visualcoat was getting, I tried your suggestion @Michel Kohanim but doesn't seem to change anything, even deleted the home to un-link everything and re-created a home, no dice.
**Edit** Never mind... I see what happened, I hadn't added any of the Google Home stuff in the Portal.  @visualcoat make sure you have it setup in the Portal > Tool > Connectivity > Google Home
Edited by wingman1487
Please forgive me, though I am not sure how to unlink my account.
Is this done in the isy portal or home app?
Thanks @Jimbo, though I do not see it linked to un-link it. Can you send a screen shot of the screen where I would unlink it?
Thank you for the help, though the UDI never shows up as a linked account.
SOLVED: The issue was that I had Microsoft Edge set as my default browser. Once I switch to my default browser back to Chrome it worked as expected.
  • 3 weeks later...
New question on the same front. I have google home linked to my ISY though only some device show up. Any suggestion on how to get the rest of them to show?
