Authenticate ISY
4.6.2 Authenticate ISY keeps popping up and sometimes program closes.  Haven't done any changes in months.  Tried clearing Java cache, still has same issue
I also note that status for all sensors is blank.....
John
Update...It has to do with the load on this computer, other computers are running ISY correctly.  How do I reload?
Regards,
John
Thanks Paul, I loaded the new ISY launcher already.  I just unloaded and reloaded Java.  Still same results.  Weird.
John
John
Make sure you check all the boxes when you clear your java cache so that any applets get deleted also
Sent from my SM-G930W8 using Tapatalk
12 minutes ago, Michel Kohanim said:
Hello JSchumann,
Very much related to firewall software:
https://wiki.universal-devices.com/index.php?title=Main_Page#Admin_Console_Closes_Automatically
Michel : "............
Enter the IP address:Port of your ISY but, instead, prefix with https. For instance, if your ISY's IP address is 192.168.0.26 and HTTPS Port for your ISY is 8226 (Admin Console | Configuration | Network), then enter https://192.168.0.26:8226
..............."     I have tried this but get message that ISY Finder can not find it.  (Of course I have used my own url)
Edited by asbril
22 minutes ago, Michel Kohanim said:
What port did you use?
8070..... I get it. Now I used 443 and it works. THANKS
Edited by asbril
OK, I found the culprit, Malwarebytes.  Now I just need to figure out what setting needs to be adjusted.  Here is the section on Java.
Regards,
John
49 minutes ago, Michel Kohanim said:
Hi John,
Boy, I have no clue what any of those things are. I would start with the first two.
Will do.  I have a question in to Malwarebytes too.  This happened after their last update.
Best Regards,
John
  • 1 month later...
Malwarebytes updated their program to fix this issue and the issue where Current State does not display.  Load version 3.5.1.2522 to get the 'fix'
Regards,
John
