NodeLink: Raspberry Pi Install Script
What version of debian are you using?  The startup issue is likely because the system is systemd and no hook to run rc.local.
To run via systemd (instead of rc.local) follow this post:
Not trying to be rude here at all - the startup script was intended for RPi newbies.  I kind of assume that someone running this with a linux VM would know enough about linux to handle a manual install.
I'll modify the script to work with standard debian/ubuntu as well.  This is where a docker install would have likely been a lot easier.
10 hours ago, carealtor said:
Thanks Paul.  This really helped and I have it running now.
What I'm still not able to fix (because I know virtually nothing about Linux) is the "startup script" portion of this.  I fumbled around and did figure out how to see what was in the /etc directory.  There is indeed no rc.local file.  Paul, you mentioned "sysctl"...  there is a sysctl.conf and a sysctl.d in /etc.
I also have Polyglot (and only Polyglot) installed on this same machine and Polyglot does start automatically.
Glad you made progress. Its one of those things that it can be hard to achieve, but once you get past it you can forget about it and it just works.
I followed generic directions similar to what io_guy posted above, but they were specifically for the pi. I've had nodelink for a while, preceding his "all in one" script. At that time I hunted around the forums and Rpi docs and worked it out that way. This one took me a little time because I'm not experienced at linux either, just enough for basic administration tasks.
Paul
Edited by paulbates
  • 1 month later...
I am having a problem installing NodeLink. OS is ver 9. Used the following command via putty.
sudo curl -sSL http://automationshack.com/Files/install.sh | bash
At the end of the installation the console shows the following  3 lines:
   ### Starting NodeLink
   ### Install complete. Login to NodeLink at http://192.168.1.252:8090
   Cannot open assembly 'home/pi/node/NodeLink.exe' File does not contain a valid CIL image.
Does anyone have any suggestions as to how I can start to track down this problem?
Debian 9 on raspberry Pi 3 B+
That script is for a Pi, you should follow the how to for Linux.
That's what I am trying to do - install it on a Raspberry pi.
Paste the whole log from a script run.
I ran the install again and took this from the terminal.
pi@raspberrypi:~ $ sudo curl -sSL http://automationshack.com/Files/install.sh | bash
### Installing dirmngr and updating to offical mono repo
dirmngr is already the newest version (2.1.18-8~deb9u4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Executing: /tmp/apt-key-gpghome.hwRmb9J9Lc/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
gpg: key A6A19B38D3D831EF: 2 signatures not checked due to missing keys
gpg: key A6A19B38D3D831EF: "Xamarin Public Jenkins (auto-signing) <releng@xamarin.com>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
deb http://download.mono-project.com/repo/debian raspbianstretch main
### Updating System - this may take several minutes
All packages are up to date.
### Installing mono and relevant dependencies - this may take several minutes
libmono-system-net-http-formatting4.0-cil is already the newest version (5.18.1.0-0xamarin4+raspbian9b1).
libmono-system-net-http-webrequest4.0-cil is already the newest version (5.18.1.0-0xamarin4+raspbian9b1).
libmono-system-net-http4.0-cil is already the newest version (5.18.1.0-0xamarin4+raspbian9b1).
mono-vbnc is already the newest version (4.7-0xamarin1+raspbian9b1).
### Creating directory
### Downloading NodeLink
### Modifying startup script
pi@raspberrypi:~ $ Cannot open assembly '/home/pi/node/NodeLink.exe': File does not contain a valid CIL image.
Odd,
I'd guess the file is getting corrupted during download for some reason.  I just tested it here with a new download and it works fine.
Thanks for checking into this.
Definitely something with how the download portion of the script ran. I repeated it several times, all with the same result. I ended up downloading NodeLink.exe directly from automationshack.com an put it in the raspi node folder. I was then able to setup the isylink node server in the isy.
I am now at the point of adding the isylink nodes for the RainMachine. Is there any documentation for adding the the 3 RainMachine nodes.
There's not.  It should be pretty straightforward.  Add the device to nodelink and then a new tab will show up.  Enter the rain ip, logon and pass and everything else should work out.
gpg:              unchanged: 1
I had this same problem, are you behind a Fortigate?
@Whitehambone     No I am not.
@io_guy
RainMachine Irrigation Controller now shows as an installed device and RainMachine now shows up in the ISY.
However, there are no zones showing up. Something I missed?
Sometimes subnodea are organized under a + sign. Are you seeing that?
If no, and it’s your first nodeserver you might have to reboot the ISY to get the node profile recognized. Typically that’s not needed, but worth a try
Paul
There is no plus in front of RainMachine. I did reboot the ISY. No change.
Paste a log of NodeLink after a reboot (of NodeLink)
Which nodelink log level should I set? Is a restart from within nodelink sufficient?
Yep.  Default levels.
Options are: Emergency, Alert, Critical, Error, Warning, Notice, Information and Debug
Are the log files supposed to appear in the node folder?
The default, notice.
Logs are only saved if you check the option.  Otherwise just cut and paste the light window.
Finally it is working. I'm not sure why the logs were not showing up. I went back to the initial NodeLink setup and started from scratch. The log then showed up, which helped a lot. I'm sure part of the problem was me being new to the raspberry pi.
Thanks much for your help. Looking forward to setting up my sprinkler programs now.
