NodeLink: Raspberry Pi Install Script
I just realized my version is getting a bit old.  V0.9.19.  What is the best way to upgrade nodelink?   Use the same install script, or can I just replace nodelink.exe?  Running on RPi.
Edited by blueman2
On the main web page is an option to autoupdate nodelink. Check that and pick a time of day to do it. Then there is nothing to do
Paul
  • 3 months later...
Just a note.
I updated the install script to now support all Raspbian versions (such as Jessie, Stretch and Buster).  It'll detect which OS version and install packages as required.
  • 1 month later...
Can't get NodeLink to accept the password for the Envisalink 3 card. I've  reinstalled twice and every time I hit the set button after inputting the password the browser spins then sets these errors. The first one says the password is incorrect but I can go the the Envisalink card web page with the password I'm using in NodeLink. Any ideas  io_guy ?
2019-08-25 18:26:14 - ISY NodeLink Server v0.9.34 started
2019-08-25 18:26:14 - OS: Linux  4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
2019-08-25 18:26:14 - Mono version: 5.18.0.240 (Debian 5.18.0.240+dfsg-3 Sat Apr 20 05:16:08 UTC 2019)
2019-08-25 18:26:15 - Web config server started (http://192.168.1.???:8090)
2019-08-25 18:26:16 - ISY resolved to 192.168.1.??? (5.0.15A)
2019-08-25 18:26:16 - ISY Node Server config detected (profile 1)with the password
2019-08-25 18:26:18 - DSC: EVL User Login - Password Incorrect [dsc1]
2019-08-25 18:27:14 - DSC Error: Data Arrival - Cannot access a disposed object.
Object name: 'System.Net.Sockets.Socket'. [dsc1]
2019-08-25 18:27:22 - DSC: No valid parameters setup for connection [dsc1]
If your password is > 6 characters only enter in the first 6.  It's a stupid EVL thing.
Oh mannnnnn...?
I already had a server running all my notifications and programs on the Rpi i installed the node...
Everything stopped working, even the display i had with all the status of my home...
  • 3 weeks later...
Hi io_guy,
I am currently have a running Raspbian with your nodelink but due to some my file-systems got corrupted, I need to do re-install Raspbian which is now running the most recent OS (Raspbian buster). I ran your curl command to install Nodelink. However, if all possible I would like to retain my current Nodelink connection in my ISY as I have many programs that are tied to those nodes. I am afraid that once I connect the new Nodelink, it will create new nodes in my ISY. Is there a way to have the new setup recognize the existing nodes?
Please advise.
Larry
Should be ok.  NodeLink auto-names nodes so unless you have multiples of the same device type you should be fine.  If you have multiple's you'd want to add them in the same order you did last time.
  • 1 month later...
Install script is now moved over to .NET Core 3.0
I re-ran the install script on my Pi.  Is the latest version V0.10.1 or V0.10.0?  My system shows the latter, but the release notes only show V0.10.1 with no mention of V0.10.0.  In addition, the auto-update doesn't seem to see the proper files and I'm getting a 404 error.  Here's the startup (w/o IP addresses) on my system:
2019-10-26 23:47:43 - ISY NodeLink Server v0.10.0 started
2019-10-26 23:47:43 - OS: Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
2019-10-26 23:47:44 - Web config server started (http://192.x.x.x:8090)
2019-10-26 23:47:44 - ISY resolved to 192.x.x.x (5.0.16)
2019-10-26 23:47:44 - ISY Node Server config detected (profile 1)
2019-10-26 23:47:45 - Auto-Update: Error updating file: The remote server returned an error: (404) Not Found.
After running the script, I repeatedly get this message through my browser (I tried reinstalling, rebooting the pi, all to no avail):
This site can’t be reached
192.168.0.228 refused to connect.
ERR_CONNECTION_REFUSEd
On 1/22/2019 at 4:52 PM, asbril said:
Major progress..... I have access to Nodelink in my browser but it keeps telling me that I have the wrong ISY credentials. I have tried both with  username/password for Administrative Console and those for ISY Portal. And each time I have restarted Nodelink to activate changes. I have also restarted the RPi but no luck with credentials.
I have also done the ps aux|greb Nodelink that you suggested
asbril, do you remember how you finally got access to the server through your browser?  I'm still being refused.
Sorry..... I don't and right now I don't use Nodelink.  Knowing my limited techie competence, I was probably guided by others in this forum and maybe that guidance is listed somewhere.
Most people have just left their ISY username as "admin". Are you sure about using an email address for an ISY username?
Your RPi reports that WiFi is blocked due to not setting your country parameter. I hope you are connected hard-wired Ethernet and not relying on WiFi for Polyglot.
Getting a segmentation fault when running the script.  Still getting connection refused from browser.  Considering doing a fresh Pi install to start over as i'm getting nowhere.
### Cleaning/Creating directories
### Installing .NET Core
### Downloading NodeLink
### Modifying startup script
### Starting NodeLink
bash: line 48:  1240 Segmentation fault      dotnet /home/pi/node/NodeLink.dll
### Install complete. Login to NodeLink at http://192.168.0.228:8090
18 minutes ago, Maresend said:
Man I'm stumped.  Brand new Raspbian stretch install, no errors, connection refused!
I see three different IP addresses that you've used in your last few posts:
192.168.0.228; 192.168.86.46; 192.168.0.29.
If you've got the right IP address, you should be able to SSH (ssh pi@192.168.0.228 for example) into that address and see if NodeLink is indeed running.  It should look something like this after you run this command: ps aux | grep Node
pi@raspberrypi:~ $ ps aux | grep Node
root       598  1.3  6.4 247164 61240 ?        Sl   Oct29  23:50 dotnet /home/pi/node/NodeLink.dll
pi        2929  2.8  6.4 252160 60640 ?        Ssl  10:13   0:21 /home/pi/dotnet/dotnet /home/pi/node/NodeLink.dll
pi        3163  0.0  0.0   7348   532 pts/0    S+   10:26   0:00 grep --color=auto Node
pi@raspberrypi:~ $
If it's not running, you won't get anything on that IP address:port
pi@raspberrypi:~ $
Bumbershoot, sorry about the IP addresses, its because I gave up on a raspberry pi that I had previously installed, installed a new one from scratch, hence the new ip address at 192.168.0.29.  Everything ran smooth as far as I could tell via the scrip, and i'm able to ssh into it no problem.  However, I don't believe Nodelink is running, and have no idea where to go next.  Running your script gave this:
pi        1574  0.0  0.4   7332  1892 pts/0    S+   17:40   0:00 grep --color=auto Node
Noticed that when tring to start NodeLink, Its getting the 5242 segementation fault again.
### Updating System - this may take several minutes
All packages are up to date.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
bash: line 48:  5242 Segmentation fault      dotnet /home/pi/node/NodeLink.dll
### Install complete. Login to NodeLink at http://192.168.0.29:8090
Any ideas as to what that means?
Nope, it's not running.
Crash.
You might try running NodeLink from the command line, and see if it sends any helpful output to the screen (I think you can just run the command that you see in output above):
Other than that, I don't know how I can help with a seg fault.
Crash.
Thanks Bumbershoot. I tried running it and it spat this out:
pi@raspberrypi:~ $ dotnet /home/pi/node/NodeLink.dll
Segmentation fault
Is it possible this is because its running on a Pi2?  Maybe doesn't have the resources?  I couldn't find a definitive answer online.
Edited by Maresend
typo
Segmentation fault
Is it possible this is because its running on a Pi2?  Maybe doesn't have to resources?  I couldn't find a definitive answer online.
No, I'm running it on a Pi2 as well, and it runs like a champ.  I think you'll have to wait for the developer to chime in here.
Ok, good to know, Thanks for your time Bumbershoot!
Can you try:
sudo apt install curl apt-transport-https
9 minutes ago, io_guy said:
Can you try:
Hi io_guy, ran this script:
pi@raspberrypi:~ $ sudo apt install curl apt-transport-https
Reading package lists... Done
Building dependency tree
Reading state information... Done
curl is already the newest version (7.64.0-4).
The following NEW packages will be installed:
  apt-transport-https
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 149 kB of archives.
After this operation, 156 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://mirrors.switch.ca/raspbian/raspbian buster/main armhf apt-transport-https all 1.8.2 [149 kB]
Fetched 149 kB in 1s (119 kB/s)
Selecting previously unselected package apt-transport-https.
(Reading database ... 39961 files and directories currently installed.)
Preparing to unpack .../apt-transport-https_1.8.2_all.deb ...
Unpacking apt-transport-https (1.8.2) ...
Setting up apt-transport-https (1.8.2) ...
Then I rebooted and looked for the process:
pi         743  0.0  0.4   7332  1816 pts/0    S+   20:52   0:00 grep --color=auto Node
should I be re-running the original install script?
