Mixing Profiles V 1.7.108
johnjces
A continuation maybe, of the last problem but I just noticed that Agave is mixing my two profiles.
My profile 1, or top profile, is Show Low. My second or lower profile is Tucson. When I go to Show Low my home page is great and Things > Switches Dimmers hows everything properly in Show Low.
When I go to Tucson My Favorites or home page, shows everythig I assigned there just fine. But when I go to Things > Switches Dimmers, I see devices that are only in Show Low. Of course when I click one of these devices only in SHow Low showing up under Tucson, I get an update failure. When I click on a Tucson switch, (I'm in the Tucson Profile), works fine.
I just noticed this as I was trying to turn off a light with the same name in both places. Got an Update failure.
SO.. things are not quite right as far as profiles.
John
John
This is still something that I can not recreate.  I am guessing that there is some stale data from a possible previous issue.  Have you tried resetting or refreshing the data in Agave?
Settings -> Data & Sync -> Refresh Data
If that does not work.  Could you put the device in debug mode and view the second profile and view the Switches/Dimmers section.  It should show me the query that is being used to pull your list.
"I see devices that are only in Show Low." This statement is wrong! What I meant is I see devices that are in Show Low AND Tucson, not just Show Low. The "Mix". If only I could write what I mean.
I will do a refresh and report back.
John
This issue is something that reappeared with the last build.
While I experienced it often before, it hadn't happened in the last two months until this last version. I had it happen to me several times since my last upgrade. Doing the refresh usually clears it for awhile, but it is not a permanent fix. It happens again.
