MobiLinc and Echo
The video instruction for installing the ISY Portal to use the Echo states that MobiLinc cannot be installed on the same ISY.  However, it is not explained what to do if this is the case.  I would prefer to use the Echo in lieu of MobiLinc, but using both would also be okay.  Does the MobiLinc module have to be uninstalled?
Got it.  Thanks.
