Install/Password/Hostname, Oh My
After running the Pi install script, NodeLink doesn't want to start up. It shows a password error and that the hostname (polyglot) can't be parsed. Any ideas?
Here's the output.
pi@polyglot:~ $ sudo curl -sSL http://automationshack.com/Files/install.sh | bash
### Installing dirmngr and updating to offical mono repo
dirmngr is already the newest version (2.1.18-8~deb9u3).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Executing: /tmp/apt-key-gpghome.939uxBNG9U/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
key A6A19B38D3D831EF:
2 signatures not checked due to missing keys
gpg: key A6A19B38D3D831EF: "Xamarin Public Jenkins (auto-signing) <releng@xamarin.com>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
deb http://download.mono-project.com/repo/debian raspbianstretch main
### Updating System - this may take several minutes
All packages are up to date.
### Installing mono and relevant dependencies - this may take several minutes
libmono-system-net-http-formatting4.0-cil is already the newest version (5.16.0.220-0xamarin4+raspbian9b1).
libmono-system-net-http-webrequest4.0-cil is already the newest version (5.16.0.220-0xamarin4+raspbian9b1).
libmono-system-net-http4.0-cil is already the newest version (5.16.0.220-0xamarin4+raspbian9b1).
mono-vbnc is already the newest version (4.7-0xamarin1+raspbian9b1).
### Creating directory
### Downloading NodeLink
### Modifying startup script
### Starting NodeLink
### Install complete. Login to NodeLink at http://10.0.1.42:8090
pi@polyglot:~ $ 2018-12-11 00:07:12 - ISY NodeLink Server v0.9.24 started
2018-12-11 00:07:12 - OS: Linux polyglot 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
2018-12-11 00:07:12 - Mono version: 5.16.0.220 (tarball Mon Nov 26 17:53:18 UTC 2018)
2018-12-11 00:07:13 - Web config server started (http://10.0.1.42:8090)
2018-12-11 00:07:13 - No password specified for the ISY
Unhandled Exception:
System.UriFormatException: Invalid URI: The hostname could not be parsed.
  at System.Uri.CreateThis (System.String uri, System.Boolean dontEscape, System.UriKind uriKind) [0x0007b] in <c0e40d34c25e4827874530676d4126b9>:0
  at System.Uri..ctor (System.String uriString) [0x00014] in <c0e40d34c25e4827874530676d4126b9>:0
  at NodeLink.RestISY.a (System.String A_0, System.Boolean A_1) [0x0009a] in <3cfda86346df48819a7b88da9fabba44>:0
  at NodeLink.RestISY.b (System.String A_0, System.Boolean A_1) [0x0000e] in <3cfda86346df48819a7b88da9fabba44>:0
  at NodeLink.RestISY.GetDescription () [0x00000] in <3cfda86346df48819a7b88da9fabba44>:0
  at NodeLink.RestISY..ctor (System.String user, System.String password, System.String address, System.Boolean SSL) [0x00687] in <3cfda86346df48819a7b88da9fabba44>:0
  at i.m () [0x00855] in <3cfda86346df48819a7b88da9fabba44>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.UriFormatException: Invalid URI: The hostname could not be parsed.
I have the same problem with
Odd, I'll have to wrap some error handling around that in the next version.  Never seen it before.
You could try adding ISY and its IP to /etc/hosts.
That worked! Thanks!
First time trying this. Thanks for the quick response. I am so excited!
Glad to hear it.
To help my debugging, what was your hostnane that didn't work?
