Error - Failed writing highwater mark
markhamk
Earlier today I upgraded to 2.7.3. I did not post this in the beta forum since there is a possibility it is not related.
I removed two devices (lamplincs) and readded. The first readded with no issues. The second fails with the following errors:
-200000 Failed writing the high water mark n/a
-200000 Note not added - failed removing link.
How do I begin to troubleshoot and resolve? Thanks
No luck so far with any of those methods....
I have this in the log:
2009/05/18 21:06:36 : CLI-WBug: Successfully Processed WBug Response
2009/05/18 21:06:41 : ---- Initializing the linked devices ----
2009/05/18 21:06:41 : ---- All Linked Devices are now initialized ----
2009/05/18 21:06:41 : ---- Add remaining devices ----
2009/05/18 21:06:41 : [ A0 31 A0 1] Removing all links
2009/05/18 21:06:41 : [A0 31 A0 1] Querying engine version
2009/05/18 21:06:41 : [iNST-ACK ] 02 62 A0.31.A0 0F 0D 00 06 (00)
2009/05/18 21:06:46 : CLI-WBug: Connecting to http://datafeed.weatherbug.com/GetXml.a ... UnitType=0
2009/05/18 21:06:46 : CLI-WBug: Successfully Processed WBug Response
2009/05/18 21:06:48 : [iNST-ACK ] 02 62 A0.31.A0 0F 0D 00 06 (00)
2009/05/18 21:06:55 : [iNST-ACK ] 02 62 A0.31.A0 0F 0D 00 06 (00)
2009/05/18 21:06:56 : CLI-WBug: Connecting to http://datafeed.weatherbug.com/GetXml.a ... UnitType=0
2009/05/18 21:06:56 : CLI-WBug: Successfully Processed WBug Response
2009/05/18 21:06:57 : [A0 31 A0 1] Failed getting engine version. Reverting to i1.
2009/05/18 21:06:57 : [] Using engine version i1
2009/05/18 21:06:57 : [iNST-ACK ] 02 62 A0.31.A0 0F 28 0F 06 SET-MSB(0F)
2009/05/18 21:07:04 : [iNST-ACK ] 02 62 A0.31.A0 0F 28 0F 06 SET-MSB(0F)
2009/05/18 21:07:06 : CLI-WBug: Connecting to http://datafeed.weatherbug.com/GetXml.a ... UnitType=0
2009/05/18 21:07:06 : CLI-WBug: Successfully Processed WBug Response
2009/05/18 21:07:11 : [iNST-ACK ] 02 62 A0.31.A0 0F 28 0F 06 SET-MSB(0F)
2009/05/18 21:07:13 : [ A0 31 A0 1] ** Not added ** Remove Device Links failed
2009/05/18 21:07:13 : ---- All Remaining Device Added ----
Hello danswatman,
Thanks for the logs. They indicate that ISY cannot even communicate with your RL. Are you sure your RL is in Programming mode and that it is within the range of an Access Point? To test, click any buttons on your RL and notice the LED on the Access Points and the PLM; make sure they blink. If not, then, in all likelihood, we either have a battery issue or a signal issue.
Rich, I must humbly ask the same questions: are you aware that your MS should be in programming mode before you can add it to any scenes?
This error started after going to latest Beta. I read other posts in the Beta 2.7.3 thread and see other communication related errors. I have not had communication errors prior to this release and there have been no changes to the topology. I am using an IS99y/IR Pro with 29 Insteon devices.
I tried again this PM with error. Event log posted.
2009/05/19 19:58:18 : [Office Table Lamp] Start : Adding to scene 'All Lights'
2009/05/19 19:58:18 : [Office Table Lamp] Making 'All Lights' a Controller
2009/05/19 19:58:18 : [Office Table Lamp] Making PLM group 17 a Controller
2009/05/19 19:58:18 : [MNG-LNK-RSP ] 02 6F 40 E2 11 0A 9A 95 01 07 32 15
2009/05/19 19:58:18 : [Office Table Lamp] Using engine version i1
2009/05/19 19:58:18 : [iNST-ACK ] 02 62 0A.9A.95 0F 28 0F 06 SET-MSB(0F)
2009/05/19 19:58:20 : [iNST-SRX ] 02 50 0A.9A.95 0F.45.0F 2B 28 0F SET-MSB(0F)
2009/05/19 19:58:25 : [iNST-ACK ] 02 62 0A.9A.95 0F 28 0F 06 SET-MSB(0F)
2009/05/19 19:58:27 : [iNST-SRX ] 02 50 0A.9A.95 0F.45.0F 2B 28 0F SET-MSB(0F)
2009/05/19 19:58:27 : [iNST-ACK ] 02 62 0A.9A.95 0F 2B F0 06 PEEK (F0)
2009/05/19 19:58:28 : [iNST-SRX ] 02 50 0A.9A.95 0F.45.0F 2B 2B A2 PEEK (A2)
2009/05/19 19:58:28 : [iNST-ACK ] 02 62 0A.9A.95 0F 28 0F 06 SET-MSB(0F)
2009/05/19 19:58:28 : [iNST-ERX ] 02 51 0A 9A 95 0F 45 0F 75 41 79 EA C4 AA 88 0F 04 F8 40 38 C3 52 92 89 0E
2009/05/19 19:58:29 : [iNST-SRX ] 02 50 0A.9A.95 0F.45.0F 23 28 0F SET-MSB(0F)
2009/05/19 19:58:29 : [iNST-ACK ] 02 62 0A.9A.95 0F 2B F1 06 PEEK (F1)
2009/05/19 19:58:30 : [iNST-SRX ] 02 50 0A.9A.95 0F.45.0F 2B 2B 11 PEEK (11)
2009/05/19 19:58:30 : [iNST-ACK ] 02 62 0A.9A.95 0F 28 0F 06 SET-MSB(0F)
2009/05/19 19:58:30 : [iNST-SRX ] 02 50 0A.9A.95 0F.45.0F 2B 28 0F SET-MSB(0F)
2009/05/19 19:58:30 : [iNST-ACK ] 02 62 0A.9A.95 0F 2B F2 06 PEEK (F2)
2009/05/19 19:58:30 : [iNST-SRX ] 02 50 0A.9A.95 0F.45.0F 2B 2B 0F PEEK (0F)
2009/05/19 19:58:31 : [iNST-ACK ] 02 62 0A.9A.95 0F 28 0F 06 SET-MSB(0F)
2009/05/19 19:58:33 : [iNST-SRX ] 02 50 0A.9A.95 0F.45.0F 2B 28 0F SET-MSB(0F)
2009/05/19 19:58:37 : [iNST-ACK ] 02 62 0A.9A.95 0F 28 0F 06 SET-MSB(0F)
2009/05/19 19:58:44 : [iNST-ACK ] 02 62 0A.9A.95 0F 28 0F 06 SET-MSB(0F)
2009/05/19 19:58:46 : [Office Table Lamp] Finish : Adding to scene 'All Lights' was Incomplete
2009/05/19 19:58:58 : [ Time] 19:59:03 3(0)
Hi Michel, yup, it is in programming mode, i can remove and re-add it as a device, it just fails when trying to add it to a scene.
I believe mine is in the programing mode??? by the holding of bright and dim and then getting the blinking light? Anyway it now seems to have the below issue when being added to any scenes....
2009/05/19 21:09:36 : [0A.31.0A.2] Start : Adding to scene 'Hallway Lights'
2009/05/19 21:09:36 : [0A.31.0A.2] Making PLM a Responder to group 2
2009/05/19 21:09:36 : [MNG-LNK-RSP ] 02 6F 41 A2 02 0A 31 0A 00 05 00 15
2009/05/19 21:09:36 : [0A.31.0A.2] Making 'Hallway:Main' a Responder
2009/05/19 21:09:36 : [0A.31.0A.2] Making 'Hallway:Control' a Responder
2009/05/19 21:09:36 : [0A.31.0A.2] Making 'Hallway:Bottom Stair' a Responder
2009/05/19 21:09:36 : [0A.31.0A.2] Making 'Hallway:Far Switch' a Responder
2009/05/19 21:09:36 : [0A.31.0A.2] Using engine version i1
2009/05/19 21:09:36 : [iNST-ACK ] 02 62 0A.31.0A 0F 28 0F 06 SET-MSB(0F)
2009/05/19 21:09:44 : [iNST-ACK ] 02 62 0A.31.0A 0F 28 0F 06 SET-MSB(0F)
2009/05/19 21:09:51 : [iNST-ACK ] 02 62 0A.31.0A 0F 28 0F 06 SET-MSB(0F)
2009/05/19 21:09:53 : [0A.31.0A.2] Finish : Adding to scene 'Hallway Lights' was Incomplete
Hello all,
Apologies for a tardy reply. It seems that in both cases, ISY fails to set MSB to 0x0F. To me, this is a very ominous sign that, perhaps, the new RLs do not respond to i1 mode messages for programming.
Would any of you be kind enough to go to Link Management | Advanced Options and check "Device Reported" and retry (please do make sure to revert to Automatic at the end of this experiment)?
Thanks and with kind regards,
Looks like you are correct the new RL which this one is seems to do fine in that device reported mode, which seems to be i2. Using that option the link works fine.
no problem with the slow reply I had pretty much decided this was a bit more than I wanted to tackle at the mommet... I did get my insteon venstar installed though....
2009/05/23 09:16:03 : [0A.31.0A.1] Start : Adding to scene 'Kitchen Main Lights'
2009/05/23 09:16:03 : [0A.31.0A.1] Making PLM a Responder to group 1
2009/05/23 09:16:03 : [MNG-LNK-RSP ] 02 6F 41 A2 01 0A 31 0A 00 05 00 15
2009/05/23 09:16:03 : [0A.31.0A.1] Making 'Kitchen:Main Lights Right' a Responder
2009/05/23 09:16:03 : [A 31 A 1] Querying engine version
2009/05/23 09:16:04 : [iNST-ACK ] 02 62 0A.31.0A 0F 0D 00 06 (00)
2009/05/23 09:16:04 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 0D 01 (01)
2009/05/23 09:16:04 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/05/23 09:16:04 : [A 31 A 1] Retrieved engine version is i2
2009/05/23 09:16:04 : [0A.31.0A.1] Using engine version i2
2009/05/23 09:16:04 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 00 0F B7 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/05/23 09:16:05 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00)
2009/05/23 09:16:05 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/05/23 09:16:06 : [iNST-ERX ] 02 51 0A 31 0A 0F D4 07 12 2F 00 00 01 0F B7 01 00 00 00 00 00 00 00 00 00
2009/05/23 09:16:06 : [Extended-Direct][0A.31.0A-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
2009/05/23 09:16:06 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 02 0F B7 08 E2 01 11 6C CF 00 00 01 00 06 (00)
2009/05/23 09:16:07 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00)
2009/05/23 09:16:07 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/05/23 09:16:07 : [11 6C CF 1] Querying engine version
2009/05/23 09:16:07 : [iNST-ACK ] 02 62 11.6C.CF 0F 0D 00 06 (00)
2009/05/23 09:16:08 : [iNST-SRX ] 02 50 11.6C.CF 0F.D4.07 2B 0D 01 (01)
2009/05/23 09:16:08 : [standard-Direct Ack][11.6C.CF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:08 : [11 6C CF 1] Retrieved engine version is i2
2009/05/23 09:16:08 : [Kitchen] Using engine version i2
2009/05/23 09:16:08 : [iNST-ACK ] 02 62 11.6C.CF 1F 2F 00 00 00 0F C7 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/05/23 09:16:08 : [iNST-SRX ] 02 50 11.6C.CF 0F.D4.07 2B 2F 00 (00)
2009/05/23 09:16:09 : [standard-Direct Ack][11.6C.CF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:09 : [iNST-ERX ] 02 51 11 6C CF 0F D4 07 11 2F 00 01 01 0F C7 01 00 00 00 00 00 00 00 00 00
2009/05/23 09:16:09 : [Extended-Direct][11.6C.CF-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/05/23 09:16:09 : [iNST-ACK ] 02 62 11.6C.CF 1F 2F 00 00 02 0F C7 08 A2 01 0A 31 0A FF 1F 01 00 06 (00)
2009/05/23 09:16:09 : [iNST-SRX ] 02 50 11.6C.CF 0F.D4.07 2B 2F 00 (00)
2009/05/23 09:16:09 : [0A.31.0A.1] Making 'Kitchen:Main Lights Left' a Responder
2009/05/23 09:16:09 : [0A.31.0A.1] Using engine version i2
2009/05/23 09:16:10 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 00 0F AF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/05/23 09:16:10 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00)
2009/05/23 09:16:11 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/05/23 09:16:11 : [iNST-ERX ] 02 51 0A 31 0A 0F D4 07 12 2F 00 00 01 0F AF 01 00 00 00 00 00 00 00 00 00
2009/05/23 09:16:11 : [Extended-Direct][0A.31.0A-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
2009/05/23 09:16:11 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 02 0F AF 08 E2 01 11 6A 06 00 00 01 00 06 (00)
2009/05/23 09:16:12 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00)
2009/05/23 09:16:12 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/05/23 09:16:12 : [11 6A 6 1] Querying engine version
2009/05/23 09:16:12 : [iNST-ACK ] 02 62 11.6A.06 0F 0D 00 06 (00)
2009/05/23 09:16:12 : [iNST-SRX ] 02 50 11.6A.06 0F.D4.07 2B 0D 01 (01)
2009/05/23 09:16:12 : [standard-Direct Ack][11.6A.06-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:12 : [11 6A 6 1] Retrieved engine version is i2
2009/05/23 09:16:12 : [Kitchen] Using engine version i2
2009/05/23 09:16:12 : [iNST-ACK ] 02 62 11.6A.06 1F 2F 00 00 00 0F C7 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/05/23 09:16:13 : [iNST-SRX ] 02 50 11.6A.06 0F.D4.07 2B 2F 00 (00)
2009/05/23 09:16:13 : [standard-Direct Ack][11.6A.06-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:13 : [iNST-ERX ] 02 51 11 6A 06 0F D4 07 11 2F 00 01 01 0F C7 01 00 00 00 00 00 00 00 00 00
2009/05/23 09:16:13 : [Extended-Direct][11.6A.06-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/05/23 09:16:13 : [iNST-ACK ] 02 62 11.6A.06 1F 2F 00 00 02 0F C7 08 A2 01 0A 31 0A FF 1F 01 00 06 (00)
2009/05/23 09:16:14 : [iNST-SRX ] 02 50 11.6A.06 0F.D4.07 2B 2F 00 (00)
2009/05/23 09:16:14 : [standard-Direct Ack][11.6A.06-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:14 : [0A.31.0A.1] Making 'Hallway:Control A' a Responder
2009/05/23 09:16:14 : [0A.31.0A.1] Using engine version i2
2009/05/23 09:16:14 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 00 0F A7 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/05/23 09:16:15 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00)
2009/05/23 09:16:15 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/05/23 09:16:15 : [iNST-ERX ] 02 51 0A 31 0A 0F D4 07 11 2F 00 00 01 0F A7 01 00 00 00 00 00 00 00 00 00
2009/05/23 09:16:15 : [Extended-Direct][0A.31.0A-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/05/23 09:16:15 : [iNST-ACK ] 02 62 0A.31.0A 1F 2F 00 00 02 0F A7 08 E2 01 07 98 0F 00 00 01 00 06 (00)
2009/05/23 09:16:16 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 27 2F 00 (00)
2009/05/23 09:16:16 : [standard-Direct Ack][0A.31.0A-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/05/23 09:16:16 : [7 98 F 1] Querying engine version
2009/05/23 09:16:16 : [iNST-ACK ] 02 62 07.98.0F 0F 0D 00 06 (00)
2009/05/23 09:16:16 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 0D 00 (00)
2009/05/23 09:16:16 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:16 : [7 98 F 1] Retrieved engine version is i1
2009/05/23 09:16:16 : [Hallway] Using engine version i1
2009/05/23 09:16:16 : [iNST-ACK ] 02 62 07.98.0F 0F 28 0F 06 SET-MSB(0F)
2009/05/23 09:16:16 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 28 0F SET-MSB(0F)
2009/05/23 09:16:17 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:17 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 60 06 PEEK (60)
2009/05/23 09:16:17 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 27 2B 00 PEEK (00)
2009/05/23 09:16:17 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/05/23 09:16:17 : [iNST-ACK ] 02 62 07.98.0F 0F 29 A2 06 POKE (A2)
2009/05/23 09:16:17 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 A2 POKE (A2)
2009/05/23 09:16:18 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 61 06 PEEK (61)
2009/05/23 09:16:18 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00)
2009/05/23 09:16:18 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:18 : [iNST-ACK ] 02 62 07.98.0F 0F 29 01 06 POKE (01)
2009/05/23 09:16:19 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 01 POKE (01)
2009/05/23 09:16:19 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:19 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 62 06 PEEK (62)
2009/05/23 09:16:19 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00)
2009/05/23 09:16:19 : [iNST-ACK ] 02 62 07.98.0F 0F 29 0A 06 POKE (0A)
2009/05/23 09:16:19 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 0A POKE (0A)
2009/05/23 09:16:20 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 63 06 PEEK (63)
2009/05/23 09:16:20 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 27 2B 00 PEEK (00)
2009/05/23 09:16:20 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/05/23 09:16:20 : [iNST-ACK ] 02 62 07.98.0F 0F 29 31 06 POKE (31)
2009/05/23 09:16:20 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 31 POKE (31)
2009/05/23 09:16:20 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:21 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 64 06 PEEK (64)
2009/05/23 09:16:21 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00)
2009/05/23 09:16:21 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:21 : [iNST-ACK ] 02 62 07.98.0F 0F 29 0A 06 POKE (0A)
2009/05/23 09:16:21 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 0A POKE (0A)
2009/05/23 09:16:22 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 65 06 PEEK (65)
2009/05/23 09:16:22 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00)
2009/05/23 09:16:22 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:22 : [iNST-ACK ] 02 62 07.98.0F 0F 29 FF 06 POKE (FF)
2009/05/23 09:16:22 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 FF POKE (FF)
2009/05/23 09:16:23 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 66 06 PEEK (66)
2009/05/23 09:16:23 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00)
2009/05/23 09:16:23 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:23 : [iNST-ACK ] 02 62 07.98.0F 0F 29 1F 06 POKE (1F)
2009/05/23 09:16:24 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 1F POKE (1F)
2009/05/23 09:16:24 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:24 : [iNST-ACK ] 02 62 07.98.0F 0F 2B 67 06 PEEK (67)
2009/05/23 09:16:24 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 2B 00 PEEK (00)
2009/05/23 09:16:24 : [iNST-ACK ] 02 62 07.98.0F 0F 29 03 06 POKE (03)
2009/05/23 09:16:24 : [iNST-SRX ] 02 50 07.98.0F 0F.D4.07 2B 29 03 POKE (03)
2009/05/23 09:16:25 : [standard-Direct Ack][07.98.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
2009/05/23 09:16:25 : [0A.31.0A.1] Finish : Adding to scene 'Kitchen Main Lights' was Successful
2009/05/23 09:16:40 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00)
2009/05/23 09:16:40 : [standard-Group][0A.31.0A-->Group=4] Max Hops=3, Hops Left=1
2009/05/23 09:16:40 : [ A 31 A 4] DON 0
2009/05/23 09:16:40 : [ A 31 A 4] ST 255
2009/05/23 09:16:41 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00)
2009/05/23 09:16:41 : [standard-Group][0A.31.0A-->Group=4] Max Hops=3, Hops Left=1
2009/05/23 09:16:41 : Duplicate: ignored
2009/05/23 09:16:41 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00): Process Message: failed
2009/05/23 09:16:41 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 41 11 04 LTONRR (04)
2009/05/23 09:16:41 : [standard-Cleanup][0A.31.0A-->ISY/PLM Group=4] Max Hops=1, Hops Left=0
2009/05/23 09:16:42 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00)
2009/05/23 09:16:42 : [standard-Group][0A.31.0A-->Group=4] Max Hops=3, Hops Left=1
2009/05/23 09:16:42 : [ A 31 A 4] DON 0
2009/05/23 09:16:42 : Duplicate: ignored
2009/05/23 09:16:42 : [iNST-SRX ] 02 50 0A.31.0A 00.00.04 C7 11 00 LTONRR (00): Process Message: failed
2009/05/23 09:16:43 : [iNST-SRX ] 02 50 0A.31.0A 0F.D4.07 41 11 04 LTONRR (04)
2009/05/23 09:16:43 : [standard-Cleanup][0A.31.0A-->ISY/PLM Group=4] Max Hops=1, Hops Left=0
danswatman,
Thanks so very much. I should be happy that we found the problem but this is not good news since some of the RLs actually do not respond to i2 commands even though they report i2. Would you be kind enough to:
1. Let me know firmware version as ISY reports it
2. Please make sure you go back to the automatic mode when you are done programming your RLs
Not sure what you mean by firmware revision isy reports it..??. it says v.00 when the RL is selected but so does my old RL.
The RL does program in that special mode you mention which leads me to believe that once the isy knows the device is an i2 the isy is able to program the RL fine.
Cheers,
Dan
Hi Dan,
Thanks so very much. I am sorry for the confusion, I was referring to the label on the RL.
Unfortunately the solution is not that simple since communications modes are not per device but per ISY. i.e. Device Reported makes ISY use device reported settings for all devices. If we are lucky, this would work OK but we cannot count on luck.
Cheers,
Dan
ok the label on the RL say 1.1 on the same label as the address, look new also because its a sticker on top of the existing label. This is again a new RL I just received.
Hello danswatman,
Thanks so very much for the update. I have reported it to SH ... hopefully they'll be able to clarify it soon.
  • 1 month later...
Hi,
I just had a problem adding a new 2420M and kept getting the following errors:
[-200000]Node not added-failed removing links[11 9F 17 1]
[-200000]Failed writing the highwater mark[n/a]
I just added a 2466SW ToggleLinc with no issues, so at first I thought I had a bad 2420M, but resolved the problem by disabling the climate module then adding the 2420M. Once the device was added I could enable the climate module and add the sensor to new scenes and programs with no further issues. Any ideas what is going wrong?
Jim
Failed device add:
2009/06/29 15:43:04 : ---- Initializing the linked devices ----
2009/06/29 15:43:04 : ---- All Linked Devices are now initialized ----
2009/06/29 15:43:04 : ---- Add remaining devices ----
2009/06/29 15:43:04 : [ 11 9F 17 1] Removing all links
2009/06/29 15:43:04 : [11 9F 17 1] Querying engine version
2009/06/29 15:43:04 : [iNST-ACK ] 02 62 11.9F.17 0F 0D 00 06 (00)
2009/06/29 15:43:04 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 0D 01 (01)
2009/06/29 15:43:04 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 15:43:04 : [11 9F 17 1] Retrieved engine version is i2
2009/06/29 15:43:04 : [11 9F 17 1] Calibrating engine version ensuring support for i2
2009/06/29 15:43:04 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:05 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 15:43:05 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 15:43:05 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 15:43:05 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 15:43:05 : [] Using engine version i2
2009/06/29 15:43:05 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:07 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 15:43:07 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 15:43:07 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 15:43:07 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 15:43:07 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:07 : CLI-WBug: Connecting to http://datafeed.weatherbug.com/GetXml.a ... UnitType=0
2009/06/29 15:43:07 : CLI-WBug: Successfully Processed WBug Response
2009/06/29 15:43:08 : [MOD 2 2 1] 000F2AD0 Weather/Temperature = 99.4 °F
2009/06/29 15:43:08 : [MOD 2 2 5] FFFFDCD8 Weather/Temperature Rate = -0.9 °F
2009/06/29 15:43:08 : [MOD 2 2 7] 00000000 Weather/Humidity Rate = 0
2009/06/29 15:43:08 : [MOD 2 2 10] 00099CF0 Weather/Dew Point = 63 °F
2009/06/29 15:43:08 : [MOD 2 2 11] 00004E20 Weather/Wind Speed = 2 mph
2009/06/29 15:43:08 : [MOD 2 2 13] 0000C350 Weather/Wind Direction = E
2009/06/29 15:43:08 : [MOD 2 2 14] 0000C350 Weather/Wind Average Directi = E
2009/06/29 15:43:08 : [MOD 2 2 18] 0000EE48 Weather/Light = 6.1
2009/06/29 15:43:08 : [MOD 2 2 19] FFF82448 Weather/Light Rate = -51.5
2009/06/29 15:43:08 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 15:43:08 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 15:43:08 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 15:43:08 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 15:43:08 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F FF 08 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:17 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F FF 08 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:26 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F FF 08 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 15:43:30 : [ 11 9F 17 1] ** Not added ** Remove Device Links failed
2009/06/29 15:43:30 : ---- All Remaining Device Added ----
Successful device add:
2009/06/29 16:40:58 : ---- Initializing the linked devices ----
2009/06/29 16:40:58 : ---- All Linked Devices are now initialized ----
2009/06/29 16:40:58 : ---- Add remaining devices ----
2009/06/29 16:40:58 : [ 11 9F 17 1] Removing all links
2009/06/29 16:40:58 : [11 9F 17 1] Querying engine version
2009/06/29 16:40:58 : [iNST-ACK ] 02 62 11.9F.17 0F 0D 00 06 (00)
2009/06/29 16:40:58 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 0D 01 (01)
2009/06/29 16:40:58 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:40:58 : [11 9F 17 1] Retrieved engine version is i2
2009/06/29 16:40:58 : [11 9F 17 1] Calibrating engine version ensuring support for i2
2009/06/29 16:40:58 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:40:59 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:40:59 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:40:59 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:40:59 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:40:59 : [] Using engine version i2
2009/06/29 16:40:59 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:00 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:00 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:00 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:00 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:00 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:01 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:01 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:01 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:01 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:01 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F FF 08 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:02 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:02 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:02 : [ 11 9F 17 1] Adding device to ISY t=10.01.0000
2009/06/29 16:41:02 : [11.9F.17-Sensor] Start : Adding device to ISY
2009/06/29 16:41:02 : [11.9F.17-Sensor] Finish : Adding device to ISY was Successful
2009/06/29 16:41:02 : [11 9F 17 1] Querying engine version
2009/06/29 16:41:02 : [iNST-ACK ] 02 62 11.9F.17 0F 0D 00 06 (00)
2009/06/29 16:41:03 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 0D 01 (01)
2009/06/29 16:41:03 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:03 : [11 9F 17 1] Retrieved engine version is i2
2009/06/29 16:41:03 : [11 9F 17 1] Calibrating engine version ensuring support for i2
2009/06/29 16:41:03 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:03 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:04 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:04 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:04 : [11.9F.17-Sensor] Making PLM a Responder to group 1
2009/06/29 16:41:04 : [MNG-LNK-RSP ] 02 6F 41 A2 01 11 9F 17 10 01 00 06
2009/06/29 16:41:04 : [11.9F.17-Sensor] Using engine version i2
2009/06/29 16:41:04 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 12 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:04 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=2, Hops Left=0
2009/06/29 16:41:04 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:05 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:05 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:05 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:05 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:05 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F FF 08 E2 01 0E D9 8A 00 00 01 00 06 (00)
2009/06/29 16:41:06 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:06 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:06 : [11.9F.17-Sensor] Making PLM a Responder to group 2
2009/06/29 16:41:06 : [MNG-LNK-RSP ] 02 6F 41 A2 02 11 9F 17 10 01 00 06
2009/06/29 16:41:06 : [11.9F.17-Sensor] Using engine version i2
2009/06/29 16:41:06 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:08 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:08 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:08 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F F7 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:08 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:08 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F F7 08 E2 02 0E D9 8A 00 00 01 00 06 (00)
2009/06/29 16:41:09 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:09 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:09 : [11.9F.17-Sensor] Making PLM a Responder to group 3
2009/06/29 16:41:09 : [MNG-LNK-RSP ] 02 6F 41 A2 03 11 9F 17 10 01 00 06
2009/06/29 16:41:09 : [11.9F.17-Sensor] Using engine version i2
2009/06/29 16:41:09 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 00 06 (00)
2009/06/29 16:41:10 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:11 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:11 : [iNST-ERX ] 02 51 11 9F 17 0E D9 8A 11 2F 00 00 01 0F EF 01 00 00 00 00 00 00 00 00 00
2009/06/29 16:41:11 : [Extended-Direct][11.9F.17-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
2009/06/29 16:41:11 : [iNST-ACK ] 02 62 11.9F.17 1F 2F 00 00 02 0F EF 08 E2 03 0E D9 8A 00 00 01 00 06 (00)
2009/06/29 16:41:11 : [iNST-SRX ] 02 50 11.9F.17 0E.D9.8A 27 2F 00 (00)
2009/06/29 16:41:12 : [standard-Direct Ack][11.9F.17-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/06/29 16:41:12 : [11.9F.17-Dusk/Dawn] Start : Adding device to ISY
2009/06/29 16:41:12 : [11.9F.17-Dusk/Dawn] Finish : Adding device to ISY was Successful
2009/06/29 16:41:12 : [11.9F.17-Low Bat] Start : Adding device to ISY
2009/06/29 16:41:12 : [11.9F.17-Low Bat] Finish : Adding device to ISY was Successful
2009/06/29 16:41:13 : [ 11 9F 17 1] Device added to ISY
2009/06/29 16:41:13 : ---- All Remaining Device Added ----
Hello Jim,
I do not think this has anything to do with your WB module but, based on the event viewer, it seems that your MS went out of programming mode (does not hear INSTEON traffic anymore).
Usually all Radio devices have a 4 minute programming mode timeout. It seems that your MS timed out and that's why it didn't respond to ISY's 3 retries.
Hello Jim,
Hi Michel,
So then it looks like the MS could be defective?
To confirm the problem, I just removed the MS and attempted to add it back. With WB enabled and polling set at the default 60sec, the MS failed when WB polled during the MS linking. I then set the WB polling to 300sec, initiated the add and the MS was added, since no WB polling occurred within the 1min 3sec it took to add the MS. Both times I made sure to set the MS in link mode just before starting the ISY link to stay within the 4min window.
I appreciate the help. I'm in the learning stages with the ISY-99i and Insteon devices, so I welcome all the advice I can get!
Jim
Hi Jim,
Just to test your scenario, I tried reproducing this problem with ISY firmware 2.7.5 and it worked fine. What ISY firmware are you using so that at the least we have the correct baseline?
Hi Michel,
I'm on ISY firmware 2.7.5 and the MS is rev1.1. I'm going to order another MS to try before sending this one back.
Jim
Hi Jim,
Thanks so very much. Please do keep us posted.
Hi Michel,
Jim
Hi Michel,
I just received 3 more 2420M sensors. All 3 MS units fail to add when the climate module is running. If I disable the modules or set polling so it does not occur during the add window, everything works fine. If the climate module polls during add it fails.
Only thing common I noticed on the MS units is the 4 digits in front of the rev.1.1 are "0909". Are these the production code?
Any ideas? Do you need me to send you one of the MS units?
Jim
      37.9k
      378.3k
