Start / Stop program with Keypad buttons
I want to be able to start and stop a program by pressing any of several insteon keypad buttons around the house.  I've read other threads about why it's not allowed to use a scene as a condition in program.  Logically this stance makes sense and I agree with it.  So what would be the proper way to do this?  Obviously (I think) the keypad buttons would be grouped together in a scene so they would turn on and off in unison.  Would I just pick one of the buttons (device) and use that in the program condition?  I've tried this, and it seems to work in my limited testing so far, but it's not very elegant, IMHO.  Maybe I'm overthinking this.
I'm on 5.0.14.
I think you'd want to expand on Michel's program since you want to start and stop based on different button pushes around the house, so maybe:
          'A-Keypad / Button A' is switched On
       Or 'B-Keypad / Button A' is switched On
       Or 'C-Keypad / Button A' is switched On
  And
          'A-Keypad / Button A' is not switched Off
       Or 'B-Keypad / Button A' is not switched Off
       Or 'C-Keypad / Button A' is not switched Off
     Run Program 'Turn Device On'
     Run Program 'Turn Device Off'
You'd still want to group the keypad buttons into a scene with each being a controller so that the LED on all of them stays in sync.  The only real problem with this approach is that if you add or remove a button from the scene, you need to update the program by adding or removing that button.  If that is a problem, I suppose you could use STATUS instead of CONTROL and then only look at one button you know will always be part of the scene.  So something like this if you know 'A-Keypad / Button A' will always be part of the scene:
     'A-Keypad / Button A' Status is On
  And
     'A-Keypad / Button A' Status is not Off
Are you trying to enable/disable programs? If so you'll follow the advice above and under then say disable program and the or else would be to enable the program.
Not sure what this means.  Do you want run THEN (start) or ELSE (stop) in a program?   Do you want to initiate a program path that has a wait state (or loop) that you want to later stop?  Enable or disable programs as suggested by lilyoyo1?
That is how I would do it
I tend to pick a couple of the buttons in the scene as the canary.  Keep in mind that (with all due respect to Mr Kohanin) I think you will need to use "status" rather than "control" in this case, just in case you use one of the scene buttons that is not specifically called out in your program.  Of course, if your program condition includes ALL your buttons in the scene, "control" conditions could work:
if
control buttonA I s on
or control buttonb is on
or.....rest of buttons
and
control buttonA is not off
control buttonB is not off
or....rest of buttons
then
start program (whatever that means)
else
stop program (whatever that means)
Yeah, "Start / Stop a program" does sound weird, and not really accurate.  Really it is just run Then or Else branches of a program.  So no, not enable/disable a program.  Rather, "on" would run the "then" which would be (for example) a series of NR calls to turn some things on, and "off" would run the "else" which would be a series of NR calls to turn things off.
Thanks for all the advice from all.  I'm going to group the buttons in a scene and use the Status from one of the buttons and that should work well in my situation.
Edited by carealtor
It should work great.  The only problem I see is if there are communication problems.  If not, it'll work great.  Make sure you use "status" for the button you choose.
