paulbates Posted April 1, 2019 Posted April 1, 2019 There's a new rainmachine rom Of interest are: - Added Local Weather Push API that allows weather data to be pushed to RainMachine either on local network or from other services. Personally don't need it but rainmachine users with a local weather station may want to check this out - Added back the local plain HTTP access by port 8081 as it was used on several 3rd party integrations. I think this was in the last beta. Its official now If my current wifi setup didn't work as well as it does I would consider the 5ghz wifi card option Paul Here's the post: Spring 2019 RainMachine devices firmware update (change log) - Added Pause feature that allows to temporarily pause watering for a certain amount. - Added Finish Before/After Sunrise or Sunset as program start time. - Added Local Weather Push API that allows weather data to be pushed to RainMachine either on local network or from other services. - Fix for Weather Underground not able to read historical data from certain stations.- Added Rotors High Rate for the higher precipitation rate rotors sprinkler type. - Added back the local plain HTTP access by port 8081 as it was used on several 3rd party integrations. RainMachine Touch HD-12/16 Family: - Added dynamic support for changing the WIFI modules. This is limited by a list of known modules that we know to be working but it can be extended. - Added support for dual-band (5GHz) WIFI adapters based on RealTek 8814 chipset.
Bumbershoot Posted April 1, 2019 Posted April 1, 2019 I've been running this software for a few weeks, but as I still have snow on the ground, I can't speak to how the controller is behaving in service. On 4/1/2019 at 12:44 PM, paulbates said: Added Local Weather Push API that allows weather data to be pushed to RainMachine either on local network or from other services. Expand For those who have a WeatherFlow weather station, the Local Weather Push is available to you, care of @bpwwer. It works like a charm!
