IFTTT Configuration
I have copied the first few steps from the instructions for configuring my ISY-994i for use with IFTTT. I have ISY Portal installed and activated. I can't figure out where to find the referenced "Select Tool | Connectivity | IFTTT" I've looked everywhere in the Admin Console but can't find it.
Setup Instructions - ISY Portal
  • On portal, IFTTT configuration is in Select Tool | Connectivity | IFTTT
  • First, you will need to click on "Set Key" to create an IFTTT Key that will be used to authenticate your IFTTT requests
Do you have an account on my.isy.io?
This is where you can configure IFTTT, not the admin console.
