ISY994i ZS PRO vs ISY994i + SEP module
@winksaville,
We already responded to your ticket. ISY994i supports INSTEON and you will need a PLM (2413S) for it to work otherwise it goes into safe mode and nothing will work. ISY994ZS PRO is for Smart Meter communication only. During the checkout, you have the option of adding Z-Wave or INSTEON support. But, if you choose neither, it will  still work.
So, if you don't have any INSTEON, you MUST get ISY994 ZS PRO.
  • 1 year later...
On 9/5/2019 at 7:00 AM, Michel Kohanim said:
@winksaville,
So, if we have INSTEON and the isy994i, can we add the referenced SEP module to connect to our electric meter (PG&E - Northern California)
Yes. As long as you do not use zwave, you'd be able to add it
