2663-222 On-Off Outlet Problem
A problem exists with this device in that a Fast On or Fast Off command DOES NOT WORK. you must use either On or Off command to have the device correctly respond to upper or lower outlet. When using either the Fast on or Fast off command ONLY the upper outlet is the only outlet to respond correctly. I am using 5.0.15A
Frank
That sounds about right. The dual outlet is like a kpl in that the primary is the top /main and the bottom is a secondary device so it behaves differently to certain commands. With it being a relay, technically there is no fast on/off. What were you hoping to accomplish
Was just trying to stay consistent and use “Fast On/Off” instead of “ “On/Off”. Learned and wanted to pass along we can NOT use Fast On/Off.
