I am excited about the new Echo flex motion sensors.
I just found out about Echo Flex ($24.99) Which has the option to add a motion sensor for $14.99.
I’m not sure what I’m going do with it yet, But it should be interesting to be able to add a couple extra echoes in hallways and bathrooms and design some routines based on its motion sensor. I’m curious how I will be able to integrate this with ISI if at all, but it is still cool even if it is limited.
  • 2 months later...
I'm kind of curious about this too - please let us know what you find out
If your utilizing the ISY Portal with your echoes now I would expect you could notify the ISY by running a program (exposed as a device in the portal) in your routine that turns on your light
All theoretical , as I don't own a flex yet
I bought some flexes and motion detectors.  I use motion detectors in Alexa routines and they work fine. Any idea how to directly link them back to the ISY?  I was  thinking about creating a scene, exposing it through the portal, and then using the Alexa routine to control the scene.  Haven’t  tried it yet....
hallway; mud room; bathrooms
I suspect you will get such a delay you will abandon that usage.
Nothing beats Insteon direct linked scenes, except ac powered wall occupancy switches for speed, unfortunately.
Sent using Tapatalk
I actually gave up and never bought an Amazon flex because the Insteon motion sensors go on sale for $29.99 or lower. I already have enough Alexa devices and I think the motion sensor will be more versatile.
My only problem right now is that the firmware version I have does not support the Insteon motion sensor.
