2 hours ago, bpwwer said:
db.nodeservers.remove({'name': 'SolarEdge'})
 The full syntax at the command line might be this: mongo polyglot --eval "db.nodeservers.remove({'name': 'DarkSky'})" and: mongo polyglot --eval "db.nodeservers.remove({'name': 'SolarEdge'})"
Worked for me...
Additionally, the update/upgrade process worked just fine here.  I'm up on the latest and greatest Polyglot, among other things:
[admin@polisy ~]$ sudo pkg update && sudo pkg upgrade
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
Password:
Updating udi repository catalogue...
pkg: Repository udi has a wrong packagesite, need to re-create database
Fetching meta.txz: 100%    820 B   0.8kB/s    00:01
Fetching packagesite.txz: 100%   45 KiB  45.9kB/s    00:01
Processing entries: 100%
udi repository update completed. 156 packages processed.
All repositories are up to date.
udi repository is up to date.
Checking for upgrades (9 candidates): 100%
Processing candidates (9 candidates): 100%
The following 9 package(s) will be affected (of 0 checked):
Installed packages to be UPGRADED:
	sudo: 1.8.27_1 -> 1.8.28p1
	python37: 3.7.4 -> 3.7.5
	python27: 2.7.16_1 -> 2.7.17
	py37-setuptools: 41.2.0 -> 41.4.0
	polyglot: 2.2.1_2 -> 2.2.4_2
	pciids: 20190725 -> 20191012
	isc-dhcp44-client: 4.4.1 -> 4.4.1_1
	ca_root_nss: 3.46.1 -> 3.47
	boost-libs: 1.71.0_1 -> 1.71.0_2
Number of packages to be upgraded: 9
The process will require 16 MiB more space.
59 MiB to be downloaded.
Proceed with this action? [y/N]: y
[1/9] Fetching sudo-1.8.28p1.txz: 100%  675 KiB 690.9kB/s    00:01
[2/9] Fetching python37-3.7.5.txz: 100%   16 MiB  16.6MB/s    00:01
[3/9] Fetching python27-2.7.17.txz: 100%   11 MiB  11.3MB/s    00:01
[4/9] Fetching py37-setuptools-41.4.0.txz: 100%  504 KiB 516.0kB/s    00:01
[5/9] Fetching polyglot-2.2.4_2.txz: 100%   17 MiB   9.1MB/s    00:02
[6/9] Fetching pciids-20191012.txz: 100%  206 KiB 211.1kB/s    00:01
[7/9] Fetching isc-dhcp44-client-4.4.1_1.txz: 100%  948 KiB 971.1kB/s    00:01
[8/9] Fetching ca_root_nss-3.47.txz: 100%  287 KiB 293.6kB/s    00:01
[9/9] Fetching boost-libs-1.71.0_2.txz: 100%   12 MiB  13.0MB/s    00:01
Checking integrity... done (0 conflicting)
[1/9] Upgrading boost-libs from 1.71.0_1 to 1.71.0_2...
[1/9] Extracting boost-libs-1.71.0_2: 100%
[2/9] Upgrading python37 from 3.7.4 to 3.7.5...
[2/9] Extracting python37-3.7.5: 100%
[3/9] Upgrading sudo from 1.8.27_1 to 1.8.28p1...
[3/9] Extracting sudo-1.8.28p1: 100%
[4/9] Upgrading python27 from 2.7.16_1 to 2.7.17...
[4/9] Extracting python27-2.7.17: 100%
[5/9] Upgrading py37-setuptools from 41.2.0 to 41.4.0...
[5/9] Extracting py37-setuptools-41.4.0: 100%
[6/9] Upgrading polyglot from 2.2.1_2 to 2.2.4_2...
===> Creating groups.
Using existing group 'polyglot'.
===> Creating users
Using existing user 'polyglot'.
[6/9] Extracting polyglot-2.2.4_2: 100%
[7/9] Upgrading pciids from 20190725 to 20191012...
[7/9] Extracting pciids-20191012: 100%
[8/9] Upgrading isc-dhcp44-client from 4.4.1 to 4.4.1_1...
[8/9] Extracting isc-dhcp44-client-4.4.1_1: 100%
[9/9] Upgrading ca_root_nss from 3.46.1 to 3.47...
[9/9] Extracting ca_root_nss-3.47: 100%
What about "ISY Portal" in slot 1?   Sorry if it was mentioned before, I just got back from traveling today and trying to catch up...
Sorry: mongo polyglot --eval "db.nodeservers.remove({'name': 'ISY Portal'})"
2 hours ago, Michel Kohanim said:
Hi @Michael,
I cannot reproduce. I even downloaded meta.txz using Windows after it succeeded on Polisy. Is it possible that you are using a proxy?
Bingo...
My outbound proxy was being a bit overzealous - the SSL cert is using a wildcard SAN name. My proxy was blocking that..  :P
[admin@polisy ~]$ true | openssl s_client -connect pkg.isy.io:443 | openssl x509 -noout -text | grep DNS:
depth=2 O = Digital Signature Trust Co., CN = DST Root CA X3
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
verify return:1
depth=0 CN = *.isy.io
verify return:1
DONE
                DNS:*.isy.io
I've bypassed the proxy for the PolISY for the time being (until I can figure out a better option). The update then worked just fine.
Thank you!
Michael.
Well - installing Polys is working now that Polyglot 2.2.4 is installed.
Weatherflow and the WirelessTag polys.
Weatherflow appears to be working - but WirelessTag is reporting the following:
2019-10-28 19:52:47,967 [MainThread] [INFO ] UDI Polyglot v2 Interface 2.0.31 Starting...
2019-10-28 19:52:48,830 [MainThread] [ERROR] Traceback (most recent call last):
2019-10-28 19:52:48,831 [MainThread] [ERROR] File "./wirelesstags-poly.py", line 8, in <module>
2019-10-28 19:52:48,832 [MainThread] [ERROR] from wt_nodes import wtController
2019-10-28 19:52:48,832 [MainThread] [ERROR] File "/var/polyglot/nodeservers/WirelessTag/wt_nodes/__init__.py", line 7, in <module>
2019-10-28 19:52:48,833 [MainThread] [ERROR] from .wTagManager  import wTagManager
2019-10-28 19:52:48,834 [MainThread] [ERROR] File "/var/polyglot/nodeservers/WirelessTag/wt_nodes/wTagManager.py", line 10, in <module>
2019-10-28 19:52:48,834 [MainThread] [ERROR] from wtServer import wtSession
2019-10-28 19:52:48,835 [MainThread] [ERROR] File "/var/polyglot/nodeservers/WirelessTag/wtServer.py", line 11, in <module>
2019-10-28 19:52:48,836 [MainThread] [ERROR] import netifaces as ni
2019-10-28 19:52:48,836 [MainThread] [ERROR] ModuleNotFoundError
2019-10-28 19:52:48,837 [MainThread] [ERROR] :
2019-10-28 19:52:48,837 [MainThread] [ERROR] No module named 'netifaces'
So - the Python module 'netifaces' is not present...
Figured I' give pip3 a go:
[admin@polisy ~]$ sudo pip3 install netifaces
Password:
Collecting netifaces
  Downloading https://files.pythonhosted.org/packages/0d/18/fd6e9c71a35b67a73160ec80a49da63d1eed2d2055054cc2995714949132/netifaces-0.10.9.tar.gz
Installing collected packages: netifaces
  Running setup.py install for netifaces ... error
    ERROR: Complete output from command /usr/local/bin/python3.7 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-z68xnvz6/netifaces/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-l5ncxh2k/install-record.txt --single-version-externally-managed --compile:
    ERROR: running install
    running build
    running build_ext
    checking for getifaddrs...not found.
    checking for getnameinfo...not found.
    checking for socket IOCTLs...not found.
    checking for optional header files...none found.
    checking whether struct sockaddr has a length field...no.
    checking which sockaddr_xxx structs are defined...none!
    checking for routing socket support...no.
    checking for sysctl(CTL_NET...) support...no.
    checking for netlink support...no.
    building 'netifaces' extension
    cc -pthread -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -O2 -pipe -fstack-protector-strong -fno-strict-aliasing -fPIC -DNETIFACES_VERSION=0.10.9 -I/usr/local/include/python3.7m -c netifaces.c -o build/temp.freebsd-12.0-RELEASE-p10-amd64-3.7/netifaces.o
    unable to execute 'cc': No such file or directory
    error: command 'cc' failed with exit status 1
ERROR: Command "/usr/local/bin/python3.7 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-z68xnvz6/netifaces/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-l5ncxh2k/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-z68xnvz6/netifaces/
Seems cc is not present...  I guess I'd need to setup a cross-compilation environment.
What should the process be to request dependent Python libraries?
Answered my own question:
[admin@polisy ~]$ sudo pkg install py37-netifaces-0.10.9
The following 1 package(s) will be affected (of 0 checked):
New packages to be INSTALLED:
        py37-netifaces: 0.10.9
Number of packages to be installed: 1
10 KiB to be downloaded.
[1/1] Fetching py37-netifaces-0.10.9.txz: 100%   10 KiB  10.4kB/s    00:01
[1/1] Installing py37-netifaces-0.10.9...
[1/1] Extracting py37-netifaces-0.10.9: 100%
Then the WirelessTag poly started just fine...
You may need to have a method that dependencies can be resolved and installed automatically. Or - Poly authors should include dependency information in the Poly metadata and Polisy should install the dependencies when Poly's are installed from the store.
2019-10-28 20:10:17 [polyglot] info: NSChild cloneRepo: Successfully cloned WirelessTag into NodeServer directory.
2019-10-28 20:10:55 [polyglot] error: NSChild: WirelessTag cloneRepo: Non-zero exit code: 128
2019-10-28 20:10:55 [polyglot] error: NSResponse: Success: false - cloneRepo: Non-zero exit code: 128
2019-10-28 20:11:25 [polyglot] error: NSChild: Install failed - Non-zero exit code: 1
2019-10-28 20:11:25 [polyglot] error: NSChild: WirelessTag cloneRepo: Error: runInstallProcess: undefined
2019-10-28 20:11:25 [polyglot] error: Error: runInstallProcess: undefined
    at runInstallProcess (/snapshot/polyglot-v2/lib/modules/children.js:45:11)
    at <anonymous>
    at process._tickCallback (internal/process/next_tick.js:188:7)
2019-10-28 20:11:25 [polyglot] error: NSResponse: Success: false - cloneRepo: Error: runInstallProcess: undefined
Poly authors do include dependancies in the requirements.txt, which is used when install.sh is run, but my cloneRepo and runInstallProcess are failing.
    at <anonymous>
Good to know.
I wonder if the current process is relying on a local compiler (not present on PolISY for obvious reasons!) - and the installation process needs instead to call the native package manager to install a binary version.
I just have one more issue with the Tesla Node.
I get this while installing.
2019-10-28 20:17:02 [polyglot] info: NSChild cloneRepo: Successfully cloned Tesla into NodeServer directory. 2019-10-28 20:17:03 [polyglot] error: NSChild: Install failed - Non-zero exit code: 127 2019-10-28 20:17:03 [polyglot] error: NSChild: Tesla cloneRepo: Error: runInstallProcess: undefined 2019-10-28 20:17:03 [polyglot] error: Error: runInstallProcess: undefined at runInstallProcess (/snapshot/polyglot-v2/lib/modules/children.js:45:11) at <anonymous> at process._tickCallback (internal/process/next_tick.js:188:7) 2019-10-28 20:17:03 [polyglot] error: NSResponse: Success: false - cloneRepo: Error: runInstallProcess: undefine
Thanks for any thoughts
Gary
1 minute ago, MWareman said:
Good to know.
Yes, that's the exact problem, I just manually ran it and get the compiler issue.  So our installation processes needs a way to call the native package manager, but for now we can just call it in the install.sh when necessary.
Gary
Run the install.sh manually and see what it says.
It’s why it’s called a geek batch! :)
Looking in /var/polyglot/nodeservers/Tesla/package.json, I see the following dependencies needed:
    "async-lock": "^1.1.4",
    "markdown": "^0.5.0",
    "polyinterface": "^1.2.3",
    "pgc_interface": "^1.0.3",
    "request": "^2.88.0",
    "request-promise-native": "^1.0.7"
I'm not as familiar with node services - or their dependencies. However - the npm binary is nowhere to be found. So - this likely needs installing first:
[admin@polisy /]# sudo pkg install npm-6.11.3
The following 4 package(s) will be affected (of 0 checked):
        npm: 6.11.3
        node: 12.13.0
        libuv: 1.33.1
        gmake: 4.2.1_3
Number of packages to be installed: 4
Uninstall and re-install the Tesla poly then appeared to work...
Now - if only someone would provide me a Tesla to test with...
Edit: In all likelihood - this is going to be needed for most (all?) node based polys....
Edited by MWareman
I am at the Tesla file in the nodserver directory but the command ./install.sh doesn't seem to be valid. Just get command not found.
Thanks Gary
Edited by garybixler
Thanks Gary
Try installing npm (I posted the command above)
I ran the fix again just to be sure but still won't install without errors or allow the command ./install.sh
However I do have my other nodes running now so I can do without the Tesla node until it can be loaded successfully from the store.
Thanks so much for all the assistance with the other nodes.
Thanks so much.
Gary
After installing npm, I had to fully remove the Tesla node (from the UI) and then delete it from the filesystem.
On reinstalling it - it worked. No manually running install.sh needed.
