Applied Locally
Mark Sanctuary
It should be visible within any scene when any one of the scene controllers is a responder. Select the controller from within the scene.
A SwitchLinc included in a scene is the best example, though a KPL could also be the same.
The difference is that a KPL can be reset remotely while most other devices have to be reset manually (remove and wait and then restore power) to make the Local Settings affective.
Rand
Rand,
Precisely. Thank you so very much.
Mark,
Yes, this is the compromise between color coding everything vs. those that are only controllers in a scene.
Rand
Mark,
You are being picky! Nonetheless, I don't see any harm moving it to the end. Consider it done. Thanks so very much.
Ok I found some.
I was wondering...and hoping that I am not being picky...could the [applied locally] be on the end of the name instead of the begining?
      38.2k
      381.2k
