Is there a simple way to run a program after boot (on v5)
Hi
I am trying to get a 1 hour timer runnig - I can start it at mid night easily - but is there a simple way to get a program to run after boot to get the tick counters running  again
Thanks - and happy New Year
4 minutes ago, Panda88 said:
Hi
Select the program in the Summary tab of the Admin Console. Right click on it and select "Enable Run at Startup". It will then the "If" section. Makes sure your "If" condition, if any, will be true.
7 hours ago, Panda88 said:
thanks
Just to be clear - the program should be enabled - but no IF statement that can trigger?
Best not to have any code in the If section as it will not likely be true with parameters not set by the system or remote systems yet.
I doubt the trigger enable option makes any difference. The If section triggers would not be calling attention to that program but rather the system would be.
'control switched' constructs would never be True, while 'status' constructs may or may not be. I forget the boot up sequence for ISY now.
17 hours ago, Panda88 said:
thanks
blank "if"  + "run at startup" = "then" clause execution at startup.  I'm not sure I agree with larrylix on the point about the "if" not working when populated.  I suppose it depends on what is in the "if" clause.  Certainly things like date and times will work correctly.  I would not count on things like device status being there at startup.  It usually takes ISY a good 15 to 30 seconds to populate all of that stuff at boot.  However, I believe a device "status" clause will trigger itself as soon as it populates.  I could be wrong, you might want to try it out.
Edited by apostolakisl
