PGC Ring updated?
TomL
I noticed in PGC Store that the Ring NS is now version 1.1.3 vs the 1.1.0 that I have installed  How do I upgrade to the newest version?  Do I delete current and install newest or just install newest?  I tried just stopping and restarting NS but that did not show any version upgrade happened.
On 1/13/2020 at 1:35 PM, MWareman said:
I'm seeing the same thing. The usual stop/start does not bring in the new version.
@bmercier ?
I'm not sure why. PGC should bring the new version when restarting. That's what James is saying.
Benoit.
On start:
  logBucket: 'pgc-prod-logbucket-[REDACTED_DATA]',
  url: 'https://github.com/UniversalDevicesInc/ring-nodeserver.git',
  isyPassword: '[REDACTED_DATA]',
  development: false,
  language: 'node',
  userId: '[REDACTED_DATA]',
   'https://[REDACTED_DATA].execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=[REDACTED_DATA]',
  timeAdded: 1561760405240,
  oauth: '<oAuth config>',
  isyVersion: '5.0.15',
  longPoll: 120,
  pgUrl:
  shortPoll: 60,
  timeStarted: 0,
  version: '1.1.0',
  netInfo:
  nodes: '<nodes>',
     publicIp: '3.89.244.35' },
   { publicPort: 30492,
   { oauth:
  customData:
     httpsIngress: 'https://pgc-ns-ingress.isy.io/ns/[REDACTED_DATA]/',
         '[REDACTED_DATA]',
        created_at: 1579398192,
      { access_token:
        token_type: 'Bearer',
         '[REDACTED_DATA]',
        refresh_token:
This was after receiving the code from Git.
Clearly - it's identifying as version 1.1.0.
And:
After restarting it and it came back up - still 1.1.0:
Michael.
On 1/18/2020 at 9:37 PM, MWareman said:
Interesting - package.json lists version 1.1.3:
https://github.com/UniversalDevicesInc/ring-nodeserver/blob/master/package.json
server.json (https://github.com/UniversalDevicesInc/ring-nodeserver/blob/master/server.json) contains version 1.,1.3 and profile_version 1.1.0:
Is this just a display bug in PGC?
Michael.
Looks like a PGC bug where the version number is not updated.
But clearly, the nodeserver is indeed updated to 1.1.3.
Benoit
Just to be clear, the images are taken from the git repository.
How can I check the actual version installed as it reports in the UI as 1.1.0?
Michael.
Michael.
1. Search for the postback url in the log:
2020-01-20 03:41:12 info: NS: Starting Subscription with postback URL https://pgc-ns-ingress.isy.io/ns/ring-<uuid>-1/event
2. Try the url in a browser, but replace "event" by "test". You should get a message saying the test is successful. This simply tests the communication to the nodeserver.
3. Now try the url in a browser once again, but remove "event", let the url finish with the forward slash. You should get a message saying "Node server is healthy". If so, this confirms you are running 1.1.3.
Benoit
Michael.
With PGC currently you can't.  This is a bug where a nodeserver version does NOT get updated in Polyglot dashboard.  The actual code running does get updated anytime the nodeserver is  stopped and started as each time it pulls the code from git.  The only way for the Polyglot dashboard to show the proper version is to REMOVE/DELETE the Nodeserver and then re-install.  Then the version will update to the current/correct version.
Benoit
All tests matched your steps - so if this confirms 1.1.3 then I'm good.
Hopefully the PGC version display bug can be fixed soon.
Michael.
Michael.
You are definitely using 1.1.3.
  • 4 months later...
I'm still running 1.1.0 based on everything in the gui and in the log.  Might explain why its not worked in weeks.  How do I get the Ring  PGC node server fixed?
Thanks.
Thanks.
Delete and reinstall the nodeserver.
I added 2nd Ring Outdoor Cam with existing cam and doorbell. The cam motion node is not showing in PGC or obviously ISY. I’ve stopped and started node several times. If delete and add back is required will I need to redo folders ring associated programs?
They may have to be edited and re-saved.
Hello,
I recently update the Ring PGC to version 1.3.0 via a delete and re-install. The stop and start did not not seem to update the version as expected. However, i am now not able to authenticate with my Ring account. I get the blue message and follow it to my Ring account and grant permission. After i do this, PGC goes into an infinite loop that never returns, and I have to kill the session and log back in to get access again. A single node appears in the ISY994 - for the controller only. I have changed slots with no change to results. I have also deleted and installed again with no effect. The previous version was working fine. What's next to get this working again?
Edited by kcrimson
Typo
On 6/17/2020 at 9:51 PM, kcrimson said:
Hello,
I would suggest to try again, I think there have been issues recently with PGC itself that are now resolved.
If you still have a problem after, we need to see what the Ring nodeserver logs are saying.
4 minutes ago, kcrimson said:
Thanks for the reply. Perhaps the PGC issues are not quite resolved yet. I am unable to login to the PGC at this time.
Their certificate expired. With them being on the west coast it may be a bit before it's up and running again
Logins are working now - due to certificate update.
Still no luck on initializing the new version of the PGC Ring. I have attached the real time log file from PGC. There are some socket errors that flash by in red that do not appear in the log when the PGC Ring is installed.
ring-0021b90202a2-6.txt
Do you get the authorization notice with the link?
If so, are you able to login with your Ring credentials when authorizing?
Benoit
Good morning.
Yes - I do get the authorization notice to connect to Ring. I follow that link to Ring, login, and then authorize on the Ring side.
I then login and receive the following Ring dialog box.
After I select "authorize" here, that is when it returns to PGC and starts the endless loop above.
Thanks for your attention on this.
Edited by kcrimson
Picture sequence wrong
      38.2k
      381.2k
