Update failed! Check polisy logs for details.
For some reason my updates showing as available in Polisy are not installing. I keep getting the message "Update failed! Check polisy logs for details."  The only system change was to the modem.  Xfinity stated that the modem I had needed to be upgraded. I installed the new modem and ran speedtest. Speedtest showed that data received was much higher than with the older modem. IP addresses had not changed however I expected them to change.  I did notice an IP address change to my ISY which I corrected in Polisy and all seemed well.  Updates however were not being installed.
Looking at the log file I saw MANY streaming lines of activity which are continuing to happen. I've attached the most recent log file below.
I'm at a loss as to how to correct this issue.   Thanks
polyglot_2020-1-17_084348.txt
A couple of things:  The log you attached is your Polyglot log, not your Polisy system log.  I suspect you'll need to look at '/var/log/messages' for information relevant to the software upgrades.
Taking a quick look at your Polyglot log, it appears that your nodeservers are all happily doing their thing.  At first glance I didn't notice any errors or problems.  They are busy, but that may just be the nature of the nodeservers you've installed.  Everything is apparently succeeding (an http status response of '200' means success).
2020-1-17 08:43:06 [polyglot] debug: MQTTP: nsCommand Message: {"command":{"address":"harmonyctrl","command":"DON"},"node":"1"}
2020-1-17 08:43:06 [polyglot] info: HarmonyHub(1): Processing command: command
2020-1-17 08:43:06 [polyglot] debug: ISY: 200 - http://192.168.50.254:5665/rest/ns/1/nodes/n001_harmonyctrl/report/cmd/DON
2020-1-17 08:43:06 [polyglot] info: HarmonyHub(1): n001_harmonyctrl :: DON sent sucessfully
2020-1-17 08:43:08 [polyglot] debug: MQTTP: nsCommand Message: {"command":{"address":"cameractrl","command":"DON"},"node":"2"}
2020-1-17 08:43:08 [polyglot] info: Camera(2): Processing command: command
2020-1-17 08:43:08 [polyglot] debug: ISY: 200 - http://192.168.50.254:5665/rest/ns/2/nodes/n002_cameractrl/report/cmd/DON
2020-1-17 08:43:08 [polyglot] info: Camera(2): n002_cameractrl :: DON sent sucessfully
Regarding the system update, there are other threads with other users noting that the update process isn't working correctly, so you're not alone.  I'm sure that UDI is well aware of the issues.
BTW, if you know how to ssh into your Polisy, you can always update it from the command line:
sudo pkg update && sudo pkg upgrade
Hello everyone, a known bug that is fixed. We should have an update on Monday at the latest. Reset button enhancement:
- 1 click = reboot
- 2 clicks = go check for updates/upgrades/missing packages/baselines and update the system (reboots afterwards)
- 3 clicks = shutdown - you need to reapply power if you  want to turn it back on
Press and hold 5-9 seconds - resets all credentials including ssh back to defaults. Restarts polyglot + UDX
Press and hold 10-20 seconds - resets networking back to DHCP, disables WiFi
Press and hold 20-30 seconds - factory reset - reboots
That log does say Polyglot but it's from the Polisy browser page. This whole process I just don't get. The web page states that the updates failed and to check the logs. I click on the logs and it says successful yet the Number of updates increase with every attempt. I'm not a stupid person but I'm not an IT programmer nor do I want to be.   Baffled at this point.
This should be added to the WIKI page because it simply said press the reset button.  Nothing further.
From what's been communicated those are "New" features in the latest release so they may not be available to everyone yet as updates are rolling out.  I'm sure it will make it into the wiki at some point.  Currently there's a lot of things going on with Polisy and documentation is not the highest of priorities until things are settled and working.
Resolved issues using PUTTY and the  commands from WIKI
I now have 5 updates that don't go through. As everything works fine, I am not particularly worried and I hesitate to use sudo and putty which are slightly beyond my technical level.
Am I correct in thinking that eventually this will be corrected by another working update ?
@asbril, I think I've understood that you run a Mac.  If so, you don't even need PuTTY.  You have a terminal built in and ready to use (and in case you're using a recent version of Windows, the Command Prompt application provides exactly the same functionality).  All that's involved is a little bit of typing on your part.
On your Mac, open the terminal app: Applications | Utilities | Terminal.app in Finder or Command - Space Bar on your keyboard, and type in terminal.app
You only have to know the IP address of your Polisy and the password for the 'admin' account.  The default password is: admin.
Just type what's in blue into the terminal at the prompt (you'll start with ssh admin....)  I only had two packages that needed updating, so your list of updates will be a bit longer.
Keep in mind that you're typing in the Polisy password twice (once to log in and once to run the 'sudo' command to start the updates) and typing "yes" or "y" three times.  The bits in blue are the only commands you'll need, and you can type those in verbatim.
Bumbershoots-Mac-mini:~ bumbershoot$ ssh admin@192.168.x.xx  (your Polisy IP address)
The authenticity of host '192.168.x.xx (192.168.x.xx)' can't be established.
ECDSA key fingerprint is SHA256:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.x.xx' (ECDSA) to the list of known hosts.
Password for admin@polisy:<type in Polisy password here - the default is admin>
Last login: Thu Jan 23 10:46:05 2020 from 192.168.x.xx
FreeBSD 12.0-RELEASE-p10 r351358 POLISY
Welcome to Polisy!
[admin@polisy ~]$ sudo pkg update && sudo pkg upgrade
Password:<type in Polisy password here - the default is admin>
Updating udi repository catalogue...
Fetching meta.txz: 100%    820 B   0.8kB/s    00:01
Fetching packagesite.txz: 100%   58 KiB  59.1kB/s    00:01
Processing entries:   0%
Newer FreeBSD version for package zsh:
To ignore this error set IGNORE_OSVERSION=yes
- package: 1201000
- running kernel: 1200086
Ignore the mismatch and continue? [Y/n]: y
Processing entries: 100%
udi repository update completed. 202 packages processed.
All repositories are up to date.
udi repository is up to date.
Checking for upgrades (2 candidates): 100%
Processing candidates (2 candidates): 100%
The following 2 package(s) will be affected (of 0 checked):
Installed packages to be UPGRADED:
    udx: 1.0.26_14 -> 1.0.26_15
    snappy: 1.1.7 -> 1.1.8
Number of packages to be upgraded: 2
564 KiB to be downloaded.
Proceed with this action? [y/N]: y
[1/2] Fetching udx-1.0.26_15.txz: 100%  542 KiB 554.7kB/s    00:01
[2/2] Fetching snappy-1.1.8.txz: 100%   22 KiB  22.9kB/s    00:01
Checking integrity... done (0 conflicting)
[1/2] Upgrading udx from 1.0.26_14 to 1.0.26_15...
[1/2] Extracting udx-1.0.26_15: 100%
[2/2] Upgrading snappy from 1.1.7 to 1.1.8...
[2/2] Extracting snappy-1.1.8: 100%
[admin@polisy ~]$sudo reboot
My issues here are resolved!
Welcome to Polisy!
- package: 1201000
Thanks so much Bumbershoot. It worked ! I used my Windows 10.
Just noticed that my WiFi config etc. is now gone. I previously disabled it because I am wired.  When I go to Settings | Polisy Config, I only see timezone.
@Michel Kohanim - I am running 1.0.26_15
Edited by rahnee
@rahneeI had the same problem. To fix, open an ssh session and then enter the following commands:
sudo service udx stop
sudo pkg delete udx
sudo pkg install udx
sudo service udx start
sudo pkg delete udx
Even better...I did nothing and now it is working.  Worrisome, yes, but I am glad it is back.
Thank you,  Issue resolved !
