Polyglot Cloud variety
I am new to this, so this may be obvious, but there are only 20-something node servers in the store. Is this likely to increase? And I saw people talking about ones that I don't see there, (myQ for instance) so I am wondering where I would find them, or how I could load them in?
Hmmmmm. I see. Thank you. I think this makes things a little more clear. Is “installing locally” Something a layman can do? I mean, I understand the words, but don’t know specifically how I would do that.
thanks
If you want to run local the easy way, get a Polisy.
thanks
That depends on you. Personally I think it's simple to set up on your own but if you're not technically inclined, you will probably struggle. At that point, Polisy would be the easiest way
