Utility Voltage on Genmon
H,i just installed Genmon on my Generac Evolution generator. The only thing is that the utility line voltage isn't displayed. Shows 0 volts. The utility voltage parameter is shown in Nodelink but is just blank. I am running Nodelink version 0.9.36.
Thanks for any info.
Gary
I found Line Voltage in the Nodelink log marked in red.
2020-01-28 16:17:31 - GenMon Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Evolution, Air Cooled"}, {"Run time": "Generator Monitor running for 1 day, 0:22:48."}, {"Power log file size": "0.00 MB of 15.00 MB"}, {"Generator Monitor Version": "V1.13.38"}]}, {"Serial Stats": [{"Packet Count": "M: 2843919, S: 2843918"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Packet Timeouts": "0"}, {"Packet Timeouts Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.81"}, {"Average Transaction Time": "0.0305 sec"}]}, {"Platform Stats": [{"CPU Temperature": "107.60 F"}, {"Pi Model": "Raspberry Pi 4 Model B Rev 1.1"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "2.33%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "1 day, 1:32:07"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "50 dBm"}, {"WLAN Signal Quality": "99/100"}, {"WLAN Signal Noise": "0 dBm"}]}]}EndOfMessage{"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.10 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Output Current": "0.00 A"}, {"Output Power (Single Phase)": "0.00 kW"}, {"Active Rotor Poles (Calculated)": "0 "}, {"Unsupported Sensors": [{"Raw RPM Sensor": "0"}, {"Frequency (Calculated)": "0.0 Hz"}, {"Unsupported Sensor 1": "0.00"}, {"Unsupported Sensor 2": "210"}, {"Unsupported Sensor 3": "1"}]}]}, {"Line": [{"Utility Voltage": "240 V"}, {"Utility Voltage Max": "247 V"}, {"Utility Voltage Min": "234 V"}, {"Utility Threshold Voltage": "156 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "01/01/13 00:04:01 Fuse Problem : Alarm Code: 2400", "Service Log": "01/27/20 15:13:07 Schedule A Serviced ", "Run Log": "01/28/20 10:04:34 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Tuesday January 28, 2020 16:17:11"}, {"Generator Time": "Tuesday January 28, 2020 16:17"}]}]}EndOfMessage{"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Evolution, Air Cooled"}, {"Run time": "Generator Monitor running for 1 day, 0:22:55."}, {"Power log file size": "0.00 MB of 15.00 MB"}, {"Generator Monitor Version": "V1.13.38"}]}, {"Serial Stats": [{"Packet Count": "M: 2844141, S: 2844140"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Packet Timeouts": "0"}, {"Packet Timeouts Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.81"}, {"Average Transaction Time": "0.0305 sec"}]}, {"Platform Stats": [{"CPU Temperature": "107.60 F"}, {"Pi Model": "Raspberry Pi 4 Model B Rev 1.1"}, {"Pi CPU Frequency Throt [genmon1]
2020-01-28 16:17:31 - GenMon: Data Error: There was an error deserializing the object of type NodeLink.GenMon+JStatusRequest. The token 'true' was expected but found 'tlin'. [genmon1]
2020-01-28 16:17:31 - GenMon Data: tling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "2.33%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "1 day, 1:32:14"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "50 dBm"}, {"WLAN Signal Quality": "97/100"}, {"WLAN Signal Noise": "0 dBm"}]}]}EndOfMessage{"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.20 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Output Current": "0.00 A"}, {"Output Power (Single Phase)": "0.00 kW"}, {"Active Rotor Poles (Calculated)": "0 "}, {"Unsupported Sensors": [{"Raw RPM Sensor": "0"}, {"Frequency (Calculated)": "0.0 Hz"}, {"Unsupported Sensor 1": "0.00"}, {"Unsupported Sensor 2": "210"}, {"Unsupported Sensor 3": "1"}]}]},
{"Line": [{"Utility Voltage": "241 V"}, {"Utility Voltage Max": "247 V"}, {"Utility Voltage Min": "234 V"}, {"Utility Threshold Voltage": "156 V"}]},
 {"Last Log Entries": {"Logs": {"Alarm Log": "01/01/13 00:04:01 Fuse Problem : Alarm Code: 2400", "Service Log": "01/27/20 15:13:07 Schedule A Serviced ", "Run Log": "01/28/20 10:04:34 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Tuesday January 28, 2020 16:17:26"}, {"Generator Time": "Tuesday January 28, 2020 16:17"}]}]}EndOfMessage{"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Evolution, Air Cooled"}, {"Run time": "Generator Monitor running for 1 day, 0:23:10."}, {"Power log file size": "0.00 MB of 15.00 MB"}, {"Generator Monitor Version": "V1.13.38"}]}, {"Serial Stats": [{"Packet Count": "M: 2844650, S: 2844649"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Packet Timeouts": "0"}, {"Packet Timeouts Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.81"}, {"Average Transaction Time": "0.0305 sec"}]}, {"Platform Stats": [{"CPU Temperature": "107.60 F"}, {"Pi Model": "Raspberry Pi 4 Model B Rev 1.1"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "2.33%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "1 day, 1:32:30"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "50 dBm"}, {"WLAN Signal Quality": "96/100"}, {"WLAN Signal Noise": "0 dBm"}]}]}EndOfMessage [genmon1]
Edited by garybixler
Update
