February 24, 20206 yr Has anyone seen or heard of their Polyisy displaying 3 LED's which continues to blink along with a persistent beeping? Upon waking up today the girl friend said there was a odd beeping coming from the secure room. Entering the room I narrowed it down to the Polyisy which has the condition I listed here. I'll create a service request for the team to diagnose but wanted to know if anyone else has seen the same? I've left my Polisy up and running to insure a proper *Burn In* as best practices but to identify DOA / Infant Mortality. Thanks!
February 24, 20206 yr I had this happen early on during the initial rollout from an update not updating the secure eprom correctly. Unless you did an update though I'm not sure why it would suddenly just happen.
February 24, 20206 yr Author 23 minutes ago, simplextech said: I had this happen early on during the initial rollout from an update not updating the secure eprom correctly. Unless you did an update though I'm not sure why it would suddenly just happen. Is this condition I describe 100% related to a firmware update? I ask because that obviously wasn't being done and haven't been working on the box for a few days. The only thing I have done is log in to check the current status of the Node Servers. I don't recall but the system doesn't have a auto update does it? All there is, is a check for update and apply option from what I recall.
February 24, 20206 yr 3 minutes ago, Teken said: Is this condition I describe 100% related to a firmware update? I ask because that obviously wasn't being done and haven't been working on the box for a few days. The only thing I have done is log in to check the current status of the Node Servers. I don't recall but the system doesn't have a auto update does it? All there is, is a check for update and apply option from what I recall. I don't know if it can occur from other things or not. I don't think there's any auto update that can be done. I would hope not. Just relaying that I've had similar (the beeping) and what was the cause when it happened with me. I'd open a support ticket.
February 24, 20206 yr Author 14 minutes ago, simplextech said: I don't know if it can occur from other things or not. I don't think there's any auto update that can be done. I would hope not. Just relaying that I've had similar (the beeping) and what was the cause when it happened with me. I'd open a support ticket. I'll work on that after lunch. Appreciate the feedback as I have lots of projects linked to this shiny blue box!
February 24, 20206 yr Just now, Teken said: I'll work on that after lunch. Appreciate the feedback as I have lots of projects linked to this shiny blue box! I got a pink one....
February 24, 20206 yr Author 59 minutes ago, simplextech said: I got a pink one.... Special, you're !
February 24, 20206 yr 2 minutes ago, Teken said: Special, you're ! Special? in the short bus way.... geek batch was mixed bag before the paint jobs
February 24, 20206 yr Author 1 minute ago, simplextech said: Special? in the short bus way.... geek batch was mixed bag before the paint jobs On that note, I'm making a 1 U server rack mount for my Polyisy. I was a little sad to see there wasn't any rabbit ears / holes for this unit or some kind of wall mounting tabs?
February 24, 20206 yr Just now, Teken said: On that note, I'm making a 1 U server rack mount for my Polyisy. I was a little sad to see there wasn't any rabbit ears / holes for this unit or some kind of wall mounting tabs? I sent that suggestion to @Michel Kohanim that they should provide a rack kit for the polisy... maybe if other's are interested it might happen?
February 24, 20206 yr Author Just now, simplextech said: I sent that suggestion to @Michel Kohanim that they should provide a rack kit for the polisy... maybe if other's are interested it might happen? The problem is the Polyisy isn't exactly 1 U in clearance I don't believe? The unit isn't very heavy so am on the fence in deciding to either use a 1 U shelf vs just a frame mount. I'll probably lean toward a shelf and use it to hold the four other 994 Series Controllers / IoT devices. Haven't made it that far since pulling miles of wire has just sucked the life out of me . . .
February 24, 20206 yr 5 minutes ago, Teken said: The problem is the Polyisy isn't exactly 1 U in clearance I don't believe? The unit isn't very heavy so am on the fence in deciding to either use a 1 U shelf vs just a frame mount. I'll probably lean toward a shelf and use it to hold the four other 994 Series Controllers / IoT devices. Haven't made it that far since pulling miles of wire has just sucked the life out of me . . . Yeah I just have mine on a shelf currently. I have the ISY units attached to DIN Rail plates in a DIN Rail enclosure in my rack. Along with a bunch of other controllers.
February 25, 20206 yr Author Just closing this topic out as this issue has been tentatively resolved. As always with the expert help of Michel at UDI. I am once again ready to rock and roll! [emoji3516]Thank You ~ Michel! [emoji106] [emoji846]Sent from my iPhone using Tapatalk
February 25, 20206 yr 21 hours ago, simplextech said: Yeah I just have mine on a shelf currently. I have the ISY units attached to DIN Rail plates in a DIN Rail enclosure in my rack. Along with a bunch of other controllers. Sorry for OT. Pictures?
February 25, 20206 yr Here's a few pics. The rack is a mess currently as I keep moving stuff around and I have some new patch panels in the mail which will help clean it up.
February 25, 20206 yr @Teken, Thank you for your time. Everyone else, we are tracking down an issue with mongodb getting corrupted. All I did was: mongodb --dbpath /var/db/mongodb --repair With kind regards, Michel
February 25, 20206 yr 1 hour ago, simplextech said: Here's a few pics. The rack is a mess currently as I keep moving stuff around and I have some new patch panels in the mail which will help clean it up. Where is the Polisy ?
February 25, 20206 yr Just now, asbril said: Where is the Polisy ? Pink box at the top of the rack to the right of the Lutron Main Repeater (white box)
February 25, 20206 yr 1 minute ago, simplextech said: Pink box at the top of the rack to the right of the Lutron Main Repeater (white box) Pink is original. Why not blue ?
February 25, 20206 yr Author 2 minutes ago, simplextech said: Pink box at the top of the rack to the right of the Lutron Main Repeater (white box) Honestly, that you were trolling me when you said it was painted - Pink!
February 25, 20206 yr 15 minutes ago, Teken said: Honestly, that you were trolling me when you said it was painted - Pink! I TOLD YOU it was PINK... WHY would i joke about such a thing!!!!!
February 25, 20206 yr 17 minutes ago, asbril said: Pink is original. Why not blue ? It was early batch raw material... pre-paint.
February 25, 20206 yr Author 3 minutes ago, simplextech said: I TOLD YOU it was PINK... WHY would i joke about such a thing!!!!! Your photo of the Ubiquity router / gateway is a perfect example of how the Polisy may in the future be configured in a 1U shelf / mount.
February 25, 20206 yr 1 minute ago, Teken said: Your photo of the Ubiquity router / gateway is a perfect example of how the Polisy may in the future be configured in a 1U shelf / mount. That was my thinking when I asked for a rack mount for polisy.... I just need to get new panels and clean up the cabling
