Program Troubleshooting
I have numerous simple programs that DO execute 99% accurately and a couple that continue to have trouble's.
The program below calls a scene of 3 (2x2466S & 1x2477S) switches. Unfortunately it does not matter what time of day any if the 3 2421 tiggerlinc's are triggered the scenee get activated.
Service Doors Lights - [ID 0035][Parent 0001]
        From    Sunset
        To       6:58:00AM (next day)
    And 'ServiceDoor-GN-Opened' Status is On
     Or 'ServiceDoor-Workshop-Opened' Status is On
     Or 'North Door Coach' is switched On
        Set 'North Yard Coach Lights' On
        Wait  2 minutes
        Set 'North Yard Coach Lights' Off
The sensors are not nor ever were directly linked to the lights. Each switch is independent and not a controller. The program calls the scene based on the If status is On.
What do you want to happen?  Without parentheses, the OR cases are probably triggering no matter what.
Change it to:
        From    Sunset
    And
        Wait  2 minutes
I create all programs using the admin console. Are you stating I am supposed to be adding parenthesis between any if's and then's? I missed that entirely reading guide :(
Here's the wiki page to read: https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Scope,_Precedence_and_Execution_Order
It's hard to tell what your intent is. but i'll add blank lines to show you how your if is being evaluated:
From    Sunset
The AND is not coupled to all 3 switches it's only coupled to the first.  The 2nd and 3rd will operate the program anytime.
