Login Credentials Window Pops Up A Lot
I would say lately the login credentials window is popping up within 10-15 minutes while the AC is open.  Sometimes within even 5 minutes.  Any ideas why this might be happening?  If I try to log back in it never completes either.  I have to restart the AC.  Thanks!
Been a very long term problem with java. It is getting more frequent lately.
Yes, I did that a few months ago and that did help back then but now it's gotten much worse.  Can you go higher than 512?  Would it help?
Have you checked your network connection between computer and ISY?
I've had Java problems preventing me from logging into ISY but once I was in, I don't get repeated login prompts..... unless I do something like reboot my router or unplug the network cable.
To check the memory situation, you can select to show the "Java Console" from the advance tab of the Java control panel. After doing this, try connecting to ISY and you will see the Java status in a separate console window.
Good luck!!
I can always connect, it just pops up as I am using it or letting it sit idle.
I checked the memory and it seems to cycle down to about 35% free and then back up to 60% or so and then repeats. Had a lot of failed to initialize errors starting up too.
Java Web Start 11.241.2.07
Using JRE version 1.8.0_241-b07 Java HotSpot(TM) Client VM
JRE expiration date: 5/17/20 12:00 AM
console.user.home = C:\Users\Brent
?   clear console window
f:   finalize objects on finalization queue
g:   garbage collect
h:   display this help message
m:   print memory usage
o:   trigger logging
p:   reload proxy configuration
q:   hide console
r:   reload policy configuration
s:   dump system and deployment properties
t:   dump thread list
v:   dump thread stack
0-5: set trace level to <n>
addNodeDefs invalid entry
----<nodeDef ID="TEMPERATURE" NLS="TMP">
    <sts>
        <st ID="ST" EDITOR="CTL_ST"/>
        <st ID="CLISPH" EDITOR="CTL_TEMP"/>
        <st ID="CLITEMP" EDITOR="CTL_TEMP"/>
        <st ID="CLISPH" EDITOR="CTL_TEMP" HIDE="T"/>
        <st ID="CLIMD" EDITOR="CTL_TEMP" HIDE="T"/>
    </sts>
    <cmds>
        <sends/>
        <accepts>
            <cmd ID="DON"/>
            <cmd ID="DOF"/>
            <cmd ID="SET_TEMP">
                <p ID="" EDITOR="CTL_TEMP" INIT="CLISPH"/>
            </cmd>
        </accepts>
    </cmds>
</nodeDef>
java.lang.IllegalArgumentException: U7DriverControl dup param [CLISPH]
    at com.universaldevices.u7.U7DriverControl.fail(Unknown Source)
    at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source)
    at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source)
    at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source)
    at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source)
    at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source)
    at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source)
    at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source)
    at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source)
    at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source)
    at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source)
    at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source)
    at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source)
    at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source)
    at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source)
    at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source)
SET_BUTTON failed to initialize
java.lang.IllegalArgumentException: [F10.I1] editor [Btn52751079] not found, ndef=[d52751079] parm=[]
    at com.universaldevices.ui.u7.U7CmdParameterWidget.<init>(Unknown Source)
    at com.universaldevices.ui.u7.U7CmdParameterWidget.createVarsOptional(Unknown Source)
    at com.universaldevices.ui.u7.U7CmdParametersPanel.initComponents(Unknown Source)
    at com.universaldevices.ui.u7.U7CmdParametersPanel.<init>(Unknown Source)
    at com.universaldevices.ui.u7.U7CmdParametersPanel.createForCmdLink(Unknown Source)
    at com.universaldevices.ui.u7.links.U7CmdEditorPanel.init(Unknown Source)
    at com.universaldevices.ui.u7.links.U7CmdEditorPanel.<init>(Unknown Source)
    at com.universaldevices.ui.u7.links.U7CmdEditorPanel.createCmd(Unknown Source)
    at com.universaldevices.ui.u7.links.U7LinkEditorsPanel.addLinkPanels(Unknown Source)
    at com.universaldevices.ui.u7.links.U7LinkPanelMgr.addNodeDef(Unknown Source)
    at com.universaldevices.ui.u7.links.U7LinkPanelMgr.init(Unknown Source)
    at com.universaldevices.ui.u7.links.U7LinkPanelMgr.<init>(Unknown Source)
    at com.universaldevices.ui.u7.links.U7GroupScenesView.startSpecific(Unknown Source)
    at com.universaldevices.ui.u7.links.U7GroupScenesView.createWidgets(Unknown Source)
SET_ACTIVITY failed to initialize
java.lang.IllegalArgumentException: [F10.I1] editor [ActDefault] not found, ndef=[HubDefault] parm=[]
java.lang.IllegalArgumentException: [F10.I1] editor [BtnDefault] not found, ndef=[DeviceDefault] parm=[]
SET_COLOR_RGB failed to initialize
java.lang.IllegalArgumentException: [F10.I12] editor [HCLRGB] not found, ndef=[SmartBulb_DTCE] parm=[R]
SET_COLOR_XY failed to initialize
java.lang.IllegalArgumentException: [F10.I12] editor [HCLXY] not found, ndef=[SmartBulb_DTCE] parm=[X]
SET_COLOR failed to initialize
java.lang.IllegalArgumentException: [F10.I12] editor [HCSEL] not found, ndef=[SmartBulb_DTCE] parm=[]
SET_HUE failed to initialize
java.lang.IllegalArgumentException: [F10.I12] editor [HCLHUE] not found, ndef=[SmartBulb_DTCE] parm=[]
SET_SAT failed to initialize
java.lang.IllegalArgumentException: [F10.I12] editor [HCLSAT] not found, ndef=[SmartBulb_DTCE] parm=[]
SET_BRI failed to initialize
java.lang.IllegalArgumentException: [F10.I12] editor [HCLBRI] not found, ndef=[SmartBulb_DTCE] parm=[]
CLITEMP failed to initialize
java.lang.IllegalArgumentException: [F10.I12] editor [HKELVIN] not found, ndef=[SmartBulb_DTCE] parm=[]
SET_CTBR failed to initialize
java.lang.IllegalArgumentException: [F10.I12] editor [HKELVIN] not found, ndef=[SmartBulb_DTCE] parm=[K]
SET_HSB failed to initialize
java.lang.IllegalArgumentException: [F10.I12] editor [HCLHUE] not found, ndef=[SmartBulb_DTCE] parm=[H]
java.lang.IllegalArgumentException: [F10.I12] editor [HCLBRI] not found, ndef=[SmartBulb_DTNE] parm=[]
java.lang.IllegalArgumentException: [F10.I12] editor [HKELVIN] not found, ndef=[SmartBulb_DTNE] parm=[]
java.lang.IllegalArgumentException: [F10.I12] editor [HKELVIN] not found, ndef=[SmartBulb_DTNE] parm=[K]
java.lang.IllegalArgumentException: [F10.I12] editor [HCLBRI] not found, ndef=[SmartBulb_DNNE] parm=[]
Memory: 250,444K  Free: 105,583K  (42%) ... completed.
Memory: 250,444K  Free: 102,857K  (41%) ... completed.
Memory: 250,444K  Free: 99,210K  (39%) ... completed.
Memory: 250,444K  Free: 98,942K  (39%) ... completed.
Memory: 250,444K  Free: 98,798K  (39%) ... completed.
Memory: 250,444K  Free: 98,467K  (39%) ... completed.
Memory: 250,444K  Free: 96,110K  (38%) ... completed.
Memory: 250,444K  Free: 94,683K  (37%) ... completed.
Memory: 256,572K  Free: 149,188K  (58%) ... completed.
Memory: 256,572K  Free: 147,666K  (57%) ... completed.
Memory: 256,572K  Free: 154,429K  (60%) ... completed.
Memory: 256,572K  Free: 154,130K  (60%) ... completed.
Memory: 256,572K  Free: 153,554K  (59%) ... completed.
Memory: 256,572K  Free: 152,998K  (59%) ... completed.
Memory: 256,572K  Free: 152,856K  (59%) ... completed.
Memory: 256,572K  Free: 152,161K  (59%) ... completed.
Memory: 256,572K  Free: 152,087K  (59%) ... completed.
Memory: 256,572K  Free: 151,958K  (59%) ... completed.
Memory: 256,572K  Free: 151,812K  (59%) ... completed.
Memory: 256,572K  Free: 151,675K  (59%) ... completed.
Memory: 256,572K  Free: 151,604K  (59%) ... completed.
Memory: 256,572K  Free: 151,530K  (59%) ... completed.
Memory: 256,572K  Free: 150,834K  (58%) ... completed.
Memory: 256,572K  Free: 150,690K  (58%) ... completed.
Memory: 256,572K  Free: 150,515K  (58%) ... completed.
Memory: 256,572K  Free: 150,443K  (58%) ... completed.
Memory: 256,572K  Free: 150,128K  (58%) ... completed.
Memory: 256,572K  Free: 150,053K  (58%) ... completed.
Memory: 256,572K  Free: 148,818K  (58%) ... completed.
Memory: 256,572K  Free: 148,674K  (57%) ... completed.
Memory: 256,572K  Free: 148,596K  (57%) ... completed.
Memory: 256,572K  Free: 148,466K  (57%) ... completed.
Memory: 256,572K  Free: 148,394K  (57%) ... completed.
Memory: 256,572K  Free: 93,228K  (36%) ... completed.
Memory: 256,572K  Free: 93,001K  (36%) ... completed.
Memory: 256,572K  Free: 92,789K  (36%) ... completed.
Memory: 256,572K  Free: 91,870K  (35%) ... completed.
Memory: 256,572K  Free: 91,664K  (35%) ... completed.
Memory: 256,572K  Free: 87,558K  (34%) ... completed.
Memory: 256,572K  Free: 86,932K  (33%) ... completed.
Memory: 256,572K  Free: 86,798K  (33%) ... completed.
Memory: 256,572K  Free: 85,537K  (33%) ... completed.
Memory: 256,572K  Free: 85,403K  (33%) ... completed.
Memory: 256,572K  Free: 85,329K  (33%) ... completed.
Memory: 256,572K  Free: 84,855K  (33%) ... completed.
Memory: 256,572K  Free: 154,878K  (60%) ... completed.
Memory: 256,572K  Free: 153,385K  (59%) ... completed.
Memory: 256,572K  Free: 151,884K  (59%) ... completed.
Memory: 256,572K  Free: 151,619K  (59%) ... completed.
Memory: 256,572K  Free: 151,474K  (59%) ... completed.
Memory: 256,572K  Free: 151,000K  (58%) ... completed.
Memory: 256,572K  Free: 149,150K  (58%) ... completed.
Memory: 256,572K  Free: 148,772K  (57%) ... completed.
Memory: 256,572K  Free: 148,630K  (57%) ... completed.
Memory: 256,572K  Free: 148,555K  (57%) ... completed.
Memory: 256,572K  Free: 148,419K  (57%) ... completed.
Memory: 256,572K  Free: 148,344K  (57%) ... completed.
Memory: 256,572K  Free: 148,166K  (57%) ... completed.
Memory: 256,572K  Free: 148,024K  (57%) ... completed.
Memory: 256,572K  Free: 147,948K  (57%) ... completed.
Memory: 256,572K  Free: 147,811K  (57%) ... completed.
Memory: 256,572K  Free: 147,627K  (57%) ... completed.
Memory: 256,572K  Free: 147,490K  (57%) ... completed.
Memory: 256,572K  Free: 147,414K  (57%) ... completed.
Memory: 256,572K  Free: 147,339K  (57%) ... completed.
Memory: 256,572K  Free: 143,644K  (55%) ... completed.
Memory: 256,572K  Free: 142,929K  (55%) ... completed.
Memory: 256,572K  Free: 142,692K  (55%) ... completed.
Memory: 256,572K  Free: 142,610K  (55%) ... completed.
Memory: 256,572K  Free: 142,469K  (55%) ... completed.
Memory: 256,572K  Free: 135,880K  (52%) ... completed.
Memory: 256,572K  Free: 135,698K  (52%) ... completed.
Memory: 256,572K  Free: 135,457K  (52%) ... completed.
you can go higher, try 1024
and BTW when java updates you have to do it again.... so a few months ago was older than the last java update... i bet your back at default.
Thanks, it had reset!  I didn't realize you had to change every time.  It is much better but still not 100%.  I had noticed that it had slowed way down as well so I should have known.
